Old 17th July 2004, 01:45 PM   #1
Shpoop is offline Shpoop  United States
Default odd little project i got goin
i know the whole idea may me illogical, but spare me
my question is this: should i soundproof the outside of the PVC before i box it and enclose the whole thing, or would it be pointless
thanks
Old 17th July 2004, 06:02 PM   #2
markp is offline markp  United States
The pvc pipe rings like a bell if you dont damp it with something. I've used Henry's roofing cement to hold lead sheets on before and it works very well. Even if you box up the whole thing you still need to damp the pipe as the resonance will come out the port end.
If it sounds good... it is good!
Old 17th July 2004, 06:14 PM   #3
yea but that wouldnt work with all the curves involved...any other suggestions?
how about the spray-on foam or the paint on soundproof liquid.
simply dampening the box with foam outside the pvc pipe wouldnt work, right?
Old 17th July 2004, 07:30 PM   #4
Default Fill materials
I've been pondering using PVC as well, but without all the curves. I assume that a thin grout or concrete (small aggregate) would be ideal although very heavy. High Expansion insulating foam (used for sealing around pipes and entry doors in home and industrial construction) is alot lighter but I'm not sure what the final resonant frequency would be.
Old 17th July 2004, 07:33 PM   #5
Lead sheeting is very flexible and can be cut into strips then applied to most of the surface. You dont have to cover every inch with the lead but do with the roofing goop. The spray foam stuff is useless for damping resonances like this, it is way to light and not internally damped.
Old 17th July 2004, 08:34 PM   #6
dhenryp is offline dhenryp  United States
Fill the box with sand.
Old 17th July 2004, 08:54 PM   #7
Works well and causes slipped disks!
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
cant get wah pedal goin! elementx Instruments and Amps 1 22nd November 2006 06:24 AM
goin 2 visit maplin 4 a pcb kit got any ideas 4 a super newbie Sord_Fish Introductions 23 21st October 2004 08:44 AM
Page generated in 0.09584 seconds (76.96% PHP - 23.04% MySQL) with 10 queries
