#11 | |
The speaker, its box (and all the dimensions therein) or the alignment are all a "physical filter" -- the great advance that theile-small did was to transform the physical aspects into electrical aspects which could be modeled. |
#12 | |
It may measure flat with a sine wave, but it's still going to sound like one-note bass.I like vented enclosures, but in general I prefer them with lower Qts woofers, and the tuning frequency lower and out of the primary musical spectrum. Like tuned 35-40hz or lower. Or I bend that rule occasionally with different woofers, such as very low Qts small woofers, or larger slightly high Qts woofers that can make use of a very low tuning frequnecy.
-Zaph|Audio- |
#13 |
diyAudio Moderator Emeritus
What's the scientific explanation for it (in layman terms)? And what do you consider acceptable GD figures generally speaking?
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#14 | |
Well, lets pick an instrument, say a kick drum. The primary tone (fundamental) that comes out of it is 60hz. But the kick drum also has harmonics all over the spectrum. probably some at 120 hz, some at 1500hz and even higher. If there were no harmonics, it would just be a simple sine wave. If there is 20 ms group delay at 60hz, the fundamental is going to be slightly delayed in comparison to the harmonics, resulting in an unnatural sound. For higher frequencies, jackinnj's description fits well. At lower frequencies it can be described as sloppy and undefined. Large kick drums are usually centered on 60hz, and the lowest string of a bass guitar is around 40hz. There are fewer harmonics in a bass guitar than a kick drum however. In general, I think you can get away with higher group delay as you move further away from the music spectrum. If I had to put a number on it, I'd say under 10 ms at 50 hz and under 12 or 14 ms at 40 hz. This is often hard to do with a vented alignment, and I often chose a non-optimum box size for vented. I still prefer vented over sealed, but only with larger woofers. I rarely vent any drivers under 5". See this thread over at the mad forum for an idea about non-optimum enclosures and group delay.
-Zaph|Audio- |
| Audax drivers still for sale | Matt D | Swap Meet | 18 | 27th March 2012 03:24 AM |
| Audax HT Set 4 Sale | dawaro | Swap Meet | 0 | 18th September 2005 07:09 AM |
| more Audax drivers still for sale | Matt D | Swap Meet | 0 | 8th December 2003 09:38 PM |
| Audax tweeters for sale | Matt D | Swap Meet | 0 | 29th October 2003 01:55 AM |
| Audax HT210F0 for sale | Kris | Swap Meet | 0 | 30th October 2000 11:00 AM |
