Old 23rd July 2004, 02:30 AM   #41
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
anyone have a diagram on how the 16 woofer/24 tweeter array is wired to get a 8 ohm load?
Old 23rd July 2004, 10:52 AM   #42
Hybrid fourdoor's Avatar
Default This week on DIYAudio.com
Try this...its from the power tapering thread thats currently going
You maintain a nice ~8 load, but you lower the output to the outer drivers. So the two at the top would be in the middle drivers, then next 4 down would be two on either side of the first two, and the 3 on either side of those last 4.
PS: This could be used for 6 drivers, 12 drivers, 20 drivers, and number in between. The intial two set the majority of the curve though.
For example if all driver were 8 ohms in the above picture, you would get a 8.7 ohm load. If you took out the 3rd row, leaving 6 you would get a 10.7 ohm load. If you changed them to 4 ohm drivers you would get 4.4 ohms and 5.3 ohms respectfully.
I enjoy my organic shapes.....
Old 23rd July 2004, 11:08 AM   #43
do you just add two more drivers to each row?
Old 23rd July 2004, 10:31 PM   #44
Yes, not the first row though. It won't affect the ohms very much...maybe go to 9 or something.
JVC Buyout Oval Spkrs for Open Baffle Line Array wrenchone Full Range 9 30th June 2009 05:06 AM
WTB: 3.5" Black Neo Buyout Drivers spudfrog Swap Meet 1 3rd October 2007 03:03 AM
FS: Line Array Drivers - 84 drivers only $200.00! Magnetar Swap Meet 1 23rd August 2007 04:34 PM
cheap buyout drivers available once again on partsexpress.com zobsky Multi-Way 3 11th September 2006 11:04 PM
IN PROGRESS: Infinity Kappa clones....buyout drivers Hybrid fourdoor Multi-Way 3 7th October 2004 07:38 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
