Old 16th July 2004, 02:26 PM   #1
chrish is offline chrish  Australia
chrish's Avatar
Default Ariel construction
G'Day Everyone,
In a previous post I was asking about experiences with subwoofers to accompany Lynn Olson's Ariel speakers. On that thread someone was asking about my experience with them, so I thought I would start a new thread to answer that question, and hopefully it may be of interest to some of you...
Building the Ariel was not as difficult as I imagined at first. The way I approached the building was to take the time to make a router template for the sides. By using a template you guarantee that both sides have identical rebates for the internal baffling. Even though I have a table saw, I had the board factory cut all the baffling to width (for accuracy). The plans called for beech or birch ply. I had difficulty sourcing this in Australia, so I used marine ply (very expensive!). I built my speakers using a kit from North Creek http://www.northcreekmusic.com/ArielFAQ.html I used the value kit, and mounted the crossover components in the upper portion of the speaker box, behind the transmission lines, with a removable back plate. I will try to attach an image of the plans, as amended by me. A friend of mine borrowed the templates and has built his using an external active crossover. He is pleased wit the result, but I have yet to listen to his pair to compare (he lives in Melbourne, I am just out of Sydney).
I finished the basic cabinets last year, and I am l am pleased with the results. These speakers really shine with vocals/jazz music. With hard rock and large orchestral works the sound is at least as good as my old speakers, but there is not the order of magnitude of improvement that I experienced wit the vocal/jazz/chamber music.
The most difficult part of the construction is what I am doing now: covering them with veneer. I decided to cover them with jarrah veneer using the PVA glue/hot iron technique. I may have done something wrong, but it was a disaster! The veneer blistered and bubbled and looked a mess! I am almost through with the tedious task of slicing the bubbles open, injecting glue underneath and re-clamping. I will post some pics of the finished speakers when they are done.
Here is a link that you have probably seen, but was somewhat useful: http://indigo.ie/~walton/ariel1.html . He does a good job, but I was left wondering, after spending mega dollars on crossover components and valve amp components, spending a few quid on a router would have saved him a whole lot of heartache!
I have driven the speakers with two amps, and old Adcom 555 and an inverted gainclone. I am building a four channel gainclone based on BrianGT’s boards, but have yet to check them out with the Ariels. My aim is to build a tube amp next year, but have yet to decide on topology/tubes. I am in the process of building an active crossover based on the boards by Rod Elliott http://sound.westhost.com/project09.htm
Please note, I have modified the plans that are posted below, they have not been checked or endorsed by the designer Lynn Olson.
Old 16th July 2004, 02:40 PM   #2
chrish's Avatar
I dont think that the changed plans came out too well in the previous post. this is a better view of the changed portion. The change is that I have used the value kit from North Creek and mounted the crossover in the upper portion of the speaker cabinet. Crossovers can be accessed with a removable rear panel.
The speaker cabinets were glued using West System two part epoxy with flocking to fill any unintentional gaps. I made the router template directly from the plans and used that to route the sides. I simply flipped the template over to make the opposite cabinet side. For the construction I first glued the back to one side and then, using the opposite side as a jig, glued a couple of the baffle pieces at a time. I used regular plastic food wrap over the top of the baffle pieces before attaching the opposite side before clamping up so that I could release the side after the glue had set. Using the epoxy gave plenty of working time for getting things right before clamping.
Will post the final pics in a few weeks when the finishing is complete.
Chris
Old 16th July 2004, 02:41 PM   #3
chrish's Avatar
Not sure how to attach multiple pictures...
Old 16th July 2004, 02:43 PM   #4
chrish's Avatar
Here is a shot of the template I constructed
Old 16th July 2004, 02:45 PM   #5
chrish's Avatar
Another shot of the template
Old 16th July 2004, 02:46 PM   #6
chrish's Avatar
These are the crossovers. North Creek value components...
Old 16th July 2004, 02:47 PM   #7
chrish's Avatar
This is the back of the front panel with scalloping behind the drivers. This was done simply with a rasp...
Old 16th July 2004, 02:50 PM   #8
chrish's Avatar
Here is a view of the two sides before any of the baffling etc has been glued on...
Old 16th July 2004, 02:53 PM   #9
chrish's Avatar
All internal baffling is glued in place. In this shot the front panel is clamped in place to check for fit.
Old 16th July 2004, 02:56 PM   #10
chrish's Avatar
This is one side with all baffling in place. Front panel yet to be glued in place (tongue and groove, so both side must be glued on before front). The crossovers are being checked for fit.
Page generated in 0.15249 seconds (63.07% PHP - 36.93% MySQL) with 11 queries
