At which frequency does "ear canal gain" start for headphones?
Old 14th July 2004, 10:49 PM   #1
454Casull is offline 454Casull  Canada
Default At which frequency does "ear canal gain" start for headphones?
Assuming a typical circumaural headphone, when would the 12dB/octave gain start?
Old 14th July 2004, 11:42 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
Default Re: At which frequency does "ear canal gain" start for headphones?
I'm not really an expert on this, but I could possibly make an educated guess. I would suggest that it would occur at the same frequency as any "room gain", just that the "room" is pretty much smaller. If the diameter of the cavity is some 4 cm, half a wavelength would fit into that at some 4 kHz. That would be a rough guesstimate. Hmm, this means that headphones should be compensated for this. Maybe they are, I don't know.
Edit: But wait, you call it "ear canal gain" in the subject line. The ear canal would have nothing to do with what I described. The ear canal acts like a pipe resonator, also around those frequencies. That resonance is responsible for the increased sensitivity of the ear in the range 1-5 kHz.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 14th July 2004, 11:59 PM   #3
Default Re: Re: At which frequency does "ear canal gain" start for headphones?
I thought the gain started at the frequency whose wavelength was longer than 1/2 the longest dimension of the volume of the listening enclosure. Wouldn't the length of the ear canal be the longest dimension?
Old 15th July 2004, 12:46 AM   #4
Svante's Avatar
454: Again, with little practical experience from this: I think that this 1/2-wavelength-of-the-biggest-dimension rule is appropriate for box shaped rooms. With headphones, we have h cavity outside the head, and then the earcanal. This is not a box-shaped room, so I guess that that rule does not nessecarily hold. OTOH the resonance in the earcanal is maybe 3kHz, so the number turns out about the same.
Why are you asking in the first place?
Old 15th July 2004, 12:51 AM   #5
I was just curious.
Actually, the question stemmed from my wondering how much excursion a headphone driver would have to undergo to produce the entire audible spectrum.
Old 15th July 2004, 03:46 AM   #6
BillFitzmaurice is offline BillFitzmaurice  United States
Banned
There's no such thing in an ear, any more than there is in a car. In small spaces pure air pressure achieved via compression of the air within the space is the medium by which frequencies are transmitted. This, by the way, is the origin of the term SPL- Sound Pressure Level.
Old 15th July 2004, 09:49 AM   #7
Svante's Avatar
The main question here is "when is the space small?". It is certainly small for low frequencies, but for high frequencies (eg 20 kHz) it is definitely large. Somewhere in between those frequencies the "room gain" starts. This frequency would be roughly 4 kHz for the headphones, roughly 100 Hz for a normal living room.
"A tweeter is big, and a woofer is small, acoustically."
Old 15th July 2004, 10:04 AM   #8
Svante's Avatar
I was just curious.
Ok, so the pressure inside a small cavity is the volume flow multiplied by the acoustic impedance of the cavity. In absolute terms:
p=U*1/(wC)
Since the velocity (v) is the derivative of displacement (x), and flow (U) is the velocity multiplied with the surface (S) of the membrane:
p=wxS/(wC)=xS/C
C is the acoustic compliance
C=V/(rho0*c^2)
so p=xS*rho0*c^2/V, or
x=pV/(S*rho0*c^2)
Assuming the p=1 Pa (94 dB), V=10e-6 m3 (10 ml), S=0.0005 m2 (5 cm2), rho0=1.2kg/m3 and c=345 m/s, the displacement would be 0.14 um. (I Hope I got it right...)
At which frequency does "ear canal gain" start for headphones?Hide this!Advertise here!
Need your opinion, how small gain can I use with LM3886 (how close to "flat amp")? danielwritesbac Chip Amps 20 30th November 2008 01:27 AM
Where does "fullrange" end and "two-way" start? KCHANG Full Range 55 1st December 2006 09:21 AM
"Start me up..." AlephX with relais control and powermanagement. joho Pass Labs 26 22nd December 2005 03:47 PM
"Double powersupply" LM3875 gain clone OA51 Chip Amps 21 8th March 2005 10:16 AM
CD frequency sweep - can hear "birdies". Circlotron Digital Source 3 19th May 2004 03:15 PM
