new 6.5 inch tang band woofer
Old 14th July 2004, 01:10 AM   #1
mightyjimbo is offline mightyjimbo  United States
Default new 6.5 inch tang band woofer
http://www.partsexpress.com/pe/showd...number=264-832
I dont know if i screwed up link but what do you guys think of the new 6.5 inch woofer? 11.5 mm of x-max. I think its really cool. Some sort of mini super sub project. I would like to make a 6th order bandpass unit with this but QTS is off? I tried some freebee modeling software and it said this. 6th order seems very complicated. Ideas for this woofer? JIMBO
Old 14th July 2004, 04:31 AM   #2
454Casull is offline 454Casull  Canada
Look at its sensitivity.
Old 14th July 2004, 05:40 AM   #3
Hybrid fourdoor is offline Hybrid fourdoor  United States
Hybrid fourdoor's Avatar
Old 14th July 2004, 01:24 PM   #4
BillFitzmaurice is offline BillFitzmaurice  United States
Banned
A driver that goes to 50Hz is not a subwoofer, no matter what the excursion. The only advantage it has is for someone who absolutely cannot use an eight. Performance that is worthy of being called a sub-woofer is available from its 8 inch big brother or from the MCM 55-2421.
Old 14th July 2004, 10:29 PM   #5
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default 83 dB on air?!!!!!!!!
I would wonder what someone want to do with an 83dB driver. Imagine it not in a corner! 79db accounting diffraction loss and room gain? wanna test your power outlet?
Old 14th July 2004, 10:46 PM   #6
DIY Headphones?
I'd say mulitiples, but geez at $40 a pop! Maybe at $20....buy 4 or so.
Old 14th July 2004, 11:16 PM   #7
cjd is offline cjd  United States
20L box ported low and it'd be a great computer sub. I don't remember the port size, but I think it was like 2"dia by 15" or similar.
C
new 6.5 inch tang band wooferHide this!Advertise here!
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 6th June 2009 12:37 AM
Tang Band W5-704D 5-1/4" Woofer-- has anybody used this? loninappleton Multi-Way 32 30th July 2008 06:35 PM
Exiting new 4 inch FR driver from Tang Band? Fast1one Full Range 1 21st May 2008 08:28 PM
Tang Band W1-1070SE - 1 inch transducer with 170 Hz Fs? arjscott Multi-Way 4 17th November 2006 03:51 PM
3-4 inch Tang Band in a TL fireman Full Range 2 28th December 2003 11:35 PM
