#2 |
transfer function magnitude
bass is also audio |
#3 |
group delay
#4 |
Pleas give some input
#5 |
btw. the cabinet is 200L
#6 |
>Can some body help me make a Overdamped cabinet for this woofer : Monacor sph-380tc
==== An 'Adire' alignment for this driver using published specs appears to be 71.65L/17Hz, but unless you have a lot of room and/or corner loaded gain or live in an apartmemt or condo, I do not believe you will find it adequate for HT, though should be fine for music with some EQ shaping to flatten in-room response. WRT your extended Fb design, it is OK as is, but considering the intended app and the driver's specs (if reasonably accurate), I would put it in a Vb = Vas/Fb = (0.707*Fs) ML-TL, with the VCs wired in parallel to keep Le low. Suggested ML-TL: L = 62" width/depth (CSA) = 270.6"^2 driver down from top 24.63" 5" diameter x 12" long vent near/at the bottom 0.2-0.4lbs/ft^3 stuffing density GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#7 | |
My english is not as good as yours
#8 |
You sure had me fooled! Since at a glance I do not see how to explain it better, I am not sure what is unclear, so please ask specific questions.
GM
#9 | |
I think i get what you meen, but i´m not sure.
#10 |
Sorry, I do not do drawings anymore, typing a response is hard enough, and to think I started my career as an achitectural, electrical draftsman and topography map maker.
I have accumulated a few CAD programs, but have not yet got around to learning how to use any of them. Anyway, it will look similar to this except with different dimensions and will require some bracing: http://www.geocities.com/rbrines1/im...LTL_Simple.jpg GM
| What about Monacor? | mr_push_pull | Multi-Way | 8 | 17th October 2010 10:41 PM |
| Monacor sph-135/AD | Tomac | Multi-Way | 22 | 30th August 2006 04:30 PM |
| Monacor | Vedo | Multi-Way | 2 | 10th February 2005 09:31 PM |
| Do know Monacor SPH-380TC ? I building a sub soon | wingman | Multi-Way | 1 | 12th July 2004 04:44 PM |
| JE Labs 300b round 5. MUSIC!! MUSIC!! | TubeHound | Tubes / Valves | 14 | 11th January 2003 12:02 AM |
| Page generated in 0.13260 seconds (72.00% PHP - 28.00% MySQL) with 11 queries |
