Old 26th May 2002, 08:42 PM   #11
dc is offline dc
Bostarob-
I have yet to see a Jasper circle cutting jig, but, according to a guy at Home Depot, the only thing securing the blade is a wing nut that may come loose with vibrations during use. He said this happened in a shop class of his once and the blade went sailing across the room and embedded itself into a wall. It seems like one should be able to avoid a tragedy by simply being aware of this and watching the wing nut, but, Home Depot no longer sells the product because of the danger it poses. So maybe there's something more to it? If not, it seems like it would be the ideal tool, provided your drill has enough torque.
I'm off to Home Depot shortly. Will come back with plenty of wood and hopefully something to cut it with.
brad
Old 27th May 2002, 05:50 AM   #12
Ouch.
I'm still a fan of the router w/ homemade jig.
Old 27th May 2002, 07:17 AM   #13
Send a message via AIM to jewilson
Default Cutting Circles
I've used the Jasper Circle Jig Model 200 several time and it works
great. You have to start by cutting the flange first then cut the speaker whole.
You should be using a 1/2 shank plunge router and a solid carbide
dual fluted spiral up cutting bit, DO NOT use a Highspeed steel
bit it will dull quickly in MDF. Take you time when cutting the speaker whole, take three passes lowering the bit 33% each pass. Of course you can't make a contiguous circle cut because you need leave the center supporting the jig. You finish the cut with a Jig Saw. This will leave you with a much cleaner circle cut than a jig saw. Remember to get the chuck on the router tight.
Check out Woodcraft or Woodworker Supply 1-800-645-9292 sales the bits and the Jasper jigs.
Good Luck
Jim W.
Old 27th May 2002, 12:58 PM   #14
dc is offline dc
Default Correction
I finally saw a picture and article of the Jasper Model 200. It's not at all what was described to me by two different hardware store employees. I have yet to see it an action, but it doesn't look dangerous at all. In fact, it looks like it would work very well. If the local Woodcraft store is open today, I'll pick one up and post my experiences.
Thanks again.
brad
Old 28th May 2002, 10:49 PM   #15
Thatch_Ear's Avatar
I have seen pics of both the rigs from Jasper and I dout they are any more dangerous than any other rig. I like a hole saw and a rotery rasp for small holes. The rasp is very dangerous because I use it in a Roto Zip. Once it gets hot if you hit a hard place the shaft will bend and the centrifical force at 30K rpm plus can have things flying off at tremendous velocities. All part of the fun. I sculpt very hard woods with this setup and have a deadman switch. I also dress for the occasion, as pieces of wood or MDF imbedded in your skin is not pleasant. Just remember as you work if the metal gets hot and cools slowly it will be soft and more apt to break. These machines are great time savers but they can kill you. Then your old lady will sell your system in a garage sale for $10. Which is a bad thing unless I am 1st to show up at the sale.
Thatch
Old 29th May 2002, 04:56 AM   #16
dc is offline dc
Default Jasper Circle Cutting Jigs Are
a very good thing. I bought a Porter Cable 693 "kit" today - motor, plunge base, fixed base and case from Woodcraft. I also bought a carbide dual flute spiral upcut bit (for cutting holes all the way through the board), a carbide 1 1/4" straight (or mortisse) bit (for cutting the shelves/notches in which the driver flanges will rest). and a Jasper Circle Cutting Jig Model 200. A number of problems meant that it took me from 9am until 7pm to get a working router and the proper collection of clamps, double-sided carpet tape, bits, etc., BUT I did get to cut three holes and a mortisse with the Jasper Circle Cutting Jig and I have to say it was one of the most satisfying experiences of my life. It was smooth, easy, fun and 100% safe.
At the time I made my original post, I was under the mistaken impression that a Jasper jig involved a post of varying length with a blade at the end that rotated around in circles. This was what was explained to me by the local Home Despot employee with whom I spoke. Obviously incorrect.
Sorry if my posts caused any confusion. I would highly recommend the Jasper jig to anyone looking to make perfect circles without a fuss. Be aware that it only works with certain routers, however (unless you drill holes in the bottom of your plunge router for the Jasper base plate).
brad
Old 29th May 2002, 01:27 PM   #17
Just finished using the Jasper Model 200 to cut 4 x 6.5" woofer cutouts recesses and baffle back cutaways + 2 x 3" tweeter holes - the best $39.95 I have ever spent on a tool. I found nothing dangerous about the jig. It's secured by two fine thread stainless phillips head screws to the bottom of your router and if you follow their directions it's easy and accurate. Watch out for the formula in Appendix A for cutting holes with a bit other than 1/4" though - it's incorrect in my version of the manual. I haven't emailed them a heads up yet
Cutting holes in aluminium enclosures emperor Parts 4 22nd July 2007 08:45 AM
cutting speaker carpet around recessed driver holes noodle_snacks Multi-Way 13 17th June 2006 08:43 AM
Cutting Nice Holes jwatts Multi-Way 10 9th February 2005 01:46 PM
Is Rotozip a good tool for cutting holes? AJ Bertelson Multi-Way 10 9th June 2004 08:36 PM
Page generated in 0.09552 seconds (80.28% PHP - 19.72% MySQL) with 10 queries
