Old 9th July 2004, 04:43 PM   #1
Default 21w8555-01
does anyone know of a nice design with (1 or 2) scanspeak 21w8555-01 ?
All links/ suggestions are welcome, closed or ported or TL Or anything
thanks!
Old 26th July 2004, 08:54 AM   #2
'come on you guys, nobody? Anything?
Old 26th July 2004, 09:29 AM   #3
Geenius is offline Geenius  Netherlands
Geenius's Avatar
eVe-II
Tony
Old 26th July 2004, 09:34 AM   #4
the eve2 has only one 8555 but it is a start.
I see it is now a closed design with Q=0,5 (how many litres?)
ok thanks Geenius!
Old 26th July 2004, 09:37 AM   #5
Hallo Aaron,
I designed a extension cabinet for my smaller bookshelf type speakers using this Scanspeak unit. Not sure how they sound though, not finished yet.
I used WinISD, if you're determined you want to use these drivers, just plug some data in Win ISD and simulate them.
Initially I wanted a closed design (because the bookshelf loudspeakers are closed as well), later on I went for maximum extension and used a tuned port (I can always close the port and still have a usable closed speaker cabinet).
Jarno.
Oemptempa petoempetapap
Old 26th July 2004, 09:40 AM   #6
Had a look at the eVe II, my system is similar (I am not quite sure how much internal volume I had, I think 50 litres).
Just go for it!
Jarno.
Old 26th July 2004, 09:41 AM   #7
Jarno
As I understand the 8555-01 was intended for closed use and the 8555-00 for ported designs I allready have 4 8555-01's so no choice here. I have used lspcad for simulation. what is the volume you are using (and port dimentions?)
Old 26th July 2004, 09:43 AM   #8
50 litres? that would make 100 ltrs total, hmmm biggies.... wil cost a fortune on wood...
Old 26th July 2004, 09:51 AM   #9
Pan is offline Pan  Sweden
It´s the other way around I believe. 00 for closed and 01 for reflex loading.
/Peter
Old 26th July 2004, 10:28 AM   #10
peter, that might be right! I am not sure about this...
Any site where we can see this information?
21w8555-01 ported deki Multi-Way 1 20th November 2006 04:38 PM
21w8851T-00 vs. 21w8555-01 ermes Multi-Way 6 10th January 2005 05:27 PM
21w8555-01 project. ermes Multi-Way 0 6th August 2004 11:43 AM
21w8555-01 need help....... ermes Multi-Way 2 15th March 2004 09:14 PM
SS 21W8555-00 T/S, please JC Fardo Multi-Way 2 26th January 2004 12:44 PM
Page generated in 0.12028 seconds (66.44% PHP - 33.56% MySQL) with 11 queries
