Old 8th July 2004, 12:57 AM   #1
Default I just bought 32 full-range drivers for $0.69 each
I Just bought 32 of these:
http://www.partsexpress.com/pe/showd...number=269-568
I bought them not because I had ideas of making good speakers out of them, but because I'm new to DIY speakers and wanted to put together some very cheap speakers to get a handle on the process. I also got some cheap tweeters, and I have some unused speakers with better drivers than the ones I just bought that I could use if I were to try to actually make decent speakers.
What I'm looking for now is ideas on different kinds of speaker designs. I'm interested in both standard and outlandish designs, remembering though that I'm new to this and have fairly limited resources. Any suggestions?
Old 8th July 2004, 10:26 AM   #2
What about using them in bessel arrays?
4 x 4 = 16 x 2 = 32...
Grretings, B.
JayBeeOnline.de
Old 8th July 2004, 11:15 AM   #3
Check out linev2.jpg. I made a couple sets of line arrays with those pioneers. They sound terrific!
Line arrays
Old 8th July 2004, 01:19 PM   #4
Banned
Something like this is certainly inexpensive but the sound is not cheap; I'd put these up against anything on the market selling for up to $500 each. Do some research on line arrays and prepare to be amazed at how good an inexpensice speaker can sound.
http://hometown.aol.com/fitzmauricew...mtbrand=AOL_US[/IMG]
Old 8th July 2004, 05:33 PM   #5
cjd is offline cjd  United States
Somewhere around here I have a network topology figured to combine with 32 of those odd shaped $0.69 Onkyo buyout tweeters PE has.
I'm running a single one of those 4" drivers with an Audax mylar buyout tweeter in an open baffle and the sound is great - as long as you're nearfield and have tons of bass EQ'd in. On my computer they're good. Further out, they sound better than they should (for $10 speakers) but those drivers are severely lacking in bass.
I'm also running those in MMTMMs in my HT right now, supported on the bottom end by an IB sub.
Lotsa fun to be had.
C
Old 9th July 2004, 03:14 AM   #6
Default question::
where is that software program that will predict frequency response for line arrays??
i.e. putting some in parallel and in series to even the frequency response.
They need a notch filter at 7kHz...
why is there a dip at 15khz and is there a way around it??
is it an interaction between dustcap and surround??
Thanks!
Old 9th July 2004, 05:22 AM   #7
thomas997's Avatar
I was looking at buying some but even for 16 they want 41 US for shipping..
Anyone buy extras and wants to sell to a canadian?
thanks
Old 9th July 2004, 11:15 AM   #8
Default Re: question::
Thanks!
http://www.pvconsultants.com/audio/frdgroup.htm
Go To VPR (Vertical Polar Response for line arrays).
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 9th July 2004, 08:04 PM   #9
Banned
Default Re: Re: question::
I don't think that's going to do what he wants it to. At any rate don't bother trying to run full range; aside from the spike the off-axis horizontal response isn't any good above 6kHz anyway. Crossover to a tweeter array at 5 to 6kHz with 3rd order filtering and the peak isn't a problem.
As for the frequency response of an array on the horizontal plane it's the same as a single driver; the vertical response narrows as the array height is increased. You don't use a parallel/series wiring scheme to even response, but you do have to do so to maintain the proper impedance load on the amp.
Old 9th July 2004, 08:19 PM   #10
jneutron's Avatar
Wow..that's expensive shipping..
I purchased 128 of them, ups ground, and it only cost me 62.72 to ship the four boxes and 10 pcs of the 3/8 tweet and 10 pcs of the 3/4 tweet (I wanted some of each to see what tweeter I was gonna use..I eventually bought 200 of the 3/8 dome..)
Cheers, John
How do you run your sub with full range drivers? gnugear Full Range 10 21st May 2008 11:01 PM
I know there are more full range drivers . . . what about . . . Kensai Full Range 21 19th December 2005 04:50 PM
full range drivers.... navin Multi-Way 0 8th December 2003 06:00 PM
Full Range Drivers Mohan Varkey Introductions 11 3rd February 2002 10:27 AM
Page generated in 0.11112 seconds (77.75% PHP - 22.25% MySQL) with 10 queries
