Old 7th July 2004, 11:43 PM   #1
Matttcattt's Avatar
Default Linkwitz Transform with multiple/isobaric drivers
How can I use the Linkwitz Transform spreadsheet to calculate the component values for use with multiple drivers, or multiple drivers in isobaric configuration?
I would guess I need to double or half some of the T/S parameters involved.
Any answers/links appreciated.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 8th July 2004, 01:32 AM   #2
SY's Avatar
Well, when you think about it, multiple drivers with close spacing (wrt the wavelengths involved!) really act like a single driver. In the case of paralleled drivers both mounted on the baffle, they're the equivalent of a driver with the same Qts, the same fs, half the Z, twice the Sd, and twice the Vas. In isobaric, they act as a single equivalent driver with the same Qts, same Sd, same fs, half the Z (assuming you've got them wired in parallel), and half the Vas.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 8th July 2004, 10:23 AM   #3
Matttcattt's Avatar
Thanks very much.
WTB: Linkwitz Transform PCB's ShinOBIWAN Swap Meet 34 17th June 2007 09:04 PM
Linkwitz Transform PCB help mikee55 Subwoofers 2 3rd October 2006 09:36 AM
linkwitz transform peace brainerd Subwoofers 4 31st January 2006 01:13 AM
Linkwitz Transform PCB? diydave Parts 2 1st September 2005 12:05 AM
Linkwitz Transform? Aunkst Chip Amps 6 28th March 2004 11:59 PM
Page generated in 0.06839 seconds (69.75% PHP - 30.25% MySQL) with 10 queries
