Old 6th July 2004, 10:34 AM   #1
Default Gamma LA 1231 - anny good?
Hi there.
I have 4 of this 12 inch driver in stock and I was wondring if some of you have anny experience with this driver for serious Hifi use.
The drivers are quite old but can still be bought It was used in this kit speaker. They are quite sensitive and well build. I can post some pictures of them if some of you dont know the driver
http://audionova.nu/docs/gamma50.htm
I was thinking of using 1 or 2 pr channel in a closed cabinet with electronic crossover and active eq in the low end. They shall cover op to about 150 Hz.
Data:
Gamma LA 1231
Typ bas
Membranstorlek (tum) 12
Membrantyp papper
Impedans (ohm) 8ohm eller 15ohm
Frekvensomfång (Hz) 25 - 4000
Effekt (W) 150
Känslighet (dB/SPL) 94
Resonansfrekvens (Hz) 25
Vas 340
Qts 0,42
Rekommenderad delningsfrekvens (Hz) ------
Yttermått (mm) 312
Monteringshål (mm) 279
Vikt (kg) 3,5
Beställningsnummer / 15 ohm 1115/1
Beställningsnummer / 8 ohm 1115
Pris 895:-
Peter
Gamma LA 1231 Alnico woofer? stefanK Multi-Way 15 25th February 2012 07:23 AM
cal gamma dac op-amp tl071 Chilli6565 Digital Source 14 21st August 2008 10:03 PM
Gamma BBK 200F Fuling Full Range 9 11th August 2008 12:34 PM
Old Gamma bass element AuroraB Multi-Way 0 18th June 2006 09:37 PM
Page generated in 0.06372 seconds (62.98% PHP - 37.02% MySQL) with 10 queries
