Old 6th July 2004, 04:37 AM   #1
Default how do i achieve this kind of bass..
the other day i went to visit paren'ts house.. during my time i was checking an old crappy set of 2.1 speakers .. when i flipped over the subwoofer and put a cd to cover a 4" subwoofer and put something heavy on top of the cd...
the bass off the sub now was very very deep.. how do i achieve this using electrical components .. is this what overdamping is?
Old 6th July 2004, 07:14 AM   #2
Coolin is offline Coolin  Netherlands
Coolin's Avatar
I assume you closed the bass port ? This will have changed the bass response. This gives more low end bass in trade off with bass a little higher in frequency(from the port).
You wont be able to do that electronicly with that same subwoofer.
Whats better is different in many situations
Old 6th July 2004, 07:52 AM   #3
Hybrid fourdoor's Avatar
No I think he's saying he put something on the driver itself. I would think that this kept it from playing higher frequencies (like a sharper crossover), since the cone couldn't move as fast since the effective mass was different. Thus you only heard lower frequencies, making you infer it as more bass.
Just a guess though
I believe poeple do this actually to lower the Fs or something of drivers, but as the expense of upper extension, and sensitivty (since the cone is heavier its harder to move).
I enjoy my organic shapes.....
Old 6th July 2004, 03:29 PM   #4
More mass = lower Fs
Old 7th July 2004, 04:59 AM   #5
ya i put something over the woofer to limit its excursion basically..
besides this way how else can i make the cone harder to move..
is there any crossover /transform that implements this reduced cone movement?
Old 7th July 2004, 05:01 AM   #6
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
couldnt a wad of clay somewhere on the cone work?
Old 7th July 2004, 06:31 AM   #7
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
the clay would work IF you can find a way to stick it permanently without it falling off sooner or later.
Old 7th July 2004, 07:28 AM   #8
ashok's Avatar
By increasing mass you will lower the resonance frequency but will loose sensitivity ( dB/watt).
I think the damping will probably degrade.
Cheers.
AM
Old 7th July 2004, 11:59 AM   #9
lean is offline lean  Argentina
You can control cone excursion by the box alignment. If you simply add mass to the cone, youŽll get a lower Fs, but also a lower sensitivity. Also you can crate some resonaces on the cone. If you want to add mass, youŽll have to do it very carefully
lean
Old 9th July 2004, 03:13 AM   #10
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
Added mass to the cone will make your bass deeper due to lower FS it will somewhat make sensitivity go up in the extension area. It will not effect high frequency extension whatsoever. It is inductance that effects high frequency extension. If you want to cut out more highs then add an inductor in series with your speaker. If you really want deep bass get something bigger than a 4" speaker!!!
The golden rule of DIY:
Build nice, or build twice!
The Missing element in Chipamps> how to achieve tight kick drum bass with chipamp? rhythmdiy Chip Amps 28 14th August 2008 08:04 AM
What we can never achieve Madmike2 Everything Else 81 10th October 2007 01:19 AM
What kind of bass can I expect bigwill Full Range 11 3rd March 2005 04:52 PM
Page generated in 0.13905 seconds (67.19% PHP - 32.81% MySQL) with 10 queries
