Old 6th July 2004, 01:49 AM   #1
Question Snell replacement 10 inch woofer
I need some info on my snell C type 10 inch woofer.One of the woofer needs replacement and I don't know which manufactuer built the speakers for Snell.I called the company and they said they do not have a matching woofer.Does anybody know which company Snell used in the 80's?or have a Snell 10 inch woofer for sale?I really like the speakers but I don't have a solution to this problem.There are some numbers on the speaker but I can not reference it with any speaker company.If Kevin Voecks is reading this maybe he could help me?
Old 6th July 2004, 09:33 AM   #2
What's wrong with the woofer? If the surround is rotting, you can repair it.
My Snell K/IIs use peerless woofers if I remember correctly. It's been a while but back when they were in production, I remember looking up the woofer part number for fun in the Madisound catalog.
Pull the woofer out and look for a label.
Old 6th July 2004, 02:40 PM   #3
ashok's Avatar
My friend has a Snell two way floor stander.
I think there was a tweeter at the back .
The foam surround fell off ( rotted). So we picked up a rubber surround from the local market and it now works fine. Total cost of repair including materials ( for 2 woofers) was about US$2/- .
The woofer was made by Vifa ! There was a label on it.
Cheers.
AM
Old 7th July 2004, 09:49 PM   #4
Solinar is offline Solinar  United States
Default Re:
I just ordered two replacement woofers for a snell CII at 140$ each. I was told there was no replacement for a while and they were only reconing old woofers, but they recently found woofers to work as replacements and are now selling them.
Old 11th August 2004, 06:55 PM   #5
nuvistor's Avatar
I have been corresponding with Snell on a replacement woofer for type C "original", availability has been intermittent but they are available for now, cost is about $163 including USA shipping.
Old 26th March 2005, 06:13 AM   #6
amp-guy is offline amp-guy  United States
Default snell woofers
thought I would jump in here with some snell info
I have a pair of snell type J
the woofers in this model are seas CA21
the surrounds were rotted so I replaced them with new ones from Partsexpress.
I have done this successfully with a number of drivers with
excellent results every time .
allso If you want to try making phase plugs it is a good time
as you need to remove the dust cap to shim the voice coil.
i have made and installed about 8 or 9 sets of phase plugs.
Snell A3i Woofer Replacement - Help Needed tgroendahl Multi-Way 3 20th March 2009 03:27 PM
Vifa 8 inch woofer MTruslow Multi-Way 1 8th January 2009 02:24 AM
FS: Snell 6.5" - 7" mid-bass driver woofer feke67 Swap Meet 0 31st December 2007 07:11 PM
15 Inch/38cm PA (sub)woofer tubee Subwoofers 10 23rd June 2006 09:56 AM
Peter Snell, Snell model A forr Multi-Way 1 25th May 2005 11:46 AM
Page generated in 0.10136 seconds (72.02% PHP - 27.98% MySQL) with 10 queries
