Im helping someone find a replacement tweeter for a Kef Model 104 that he wants to fix and sell. I assume it will be next to impossible to find an original driver so a suitable substitute will have to do. I haven't been able to find any useful info on the web. Hopefull someone here will have some thoughts on an appropriate replacement.
thanks btw, this is the model 104 from the 70s, not the reference 104/2 |
#2 |
The tweeter is the KEF T27 I believe, has no modern equivalent.
To match the cutout diameter (nearly) you'll need a 1" tweeter, standard size is 104mm, a little less than the T27's 108mm. Mylar 1" are no longer made, I'd suggest a metal dome. http://www.madisound.com/seas/H1214.pdf Is on sale at Madisound, and looks about right, with an L-pad. Use some black beading around the 2mm that will be left around the tweeter. Also fit an 8 ohm L-pad to the rear. Make sure tweeter phasing is correct. http://www.partsexpress.com/pe/showd...number=260-250 |
#4 |
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
They are not impossible to find, but are much sought after, so not cheap. So not really the way you want go for resale, recouping costs will be extremely difficult. IMO a neat job with the Seas is the way to go, also IMO the Seas will be an upgrade over the T27. IMO Falcon Acoustics do not stock a suitable unit, and will not be able to do any better than my suggestion for a replacement. Having the original tweeter fitted is more of an issue with the KEF 104aB crossover, which is precisely tuned to the T27, which implies the 104 crossover isn't, so substitution is less of an issue. Also note my suggestion of the Seas is not a result of sticking a pin in a donkey, its a carefully considered recommendation, (but you must use the L-pad or equivalent resistors). |
#5 |
If I haven't made it clear before both T27's
need replacing, even if one is still working. You need 2 tweeters and 2 L-pads. For resale, selling the T27 that still works (if this is the case) seperately makes the most sense to me. |
#6 |
I've got a spare T27 SP 1032 if your interested.
Cheers Anthony Kirby |
#7 |
Praudio |
#8 |
Thanks all. Sreten, thanks for your particularly helpful info.
Praudio and ANTHONY2181, I have to talk to the guy that actually owns these and see what he wants to do. I suspect he will want to get these so I'll let you know ASAP. I didn't think this would be so easy |
#9 |
For you Canadians the Praudio option is obviously the
one to go for if only one tweeter has met its demise. End of story ....... I never considered that the post was considering replacing only one tweeter with a substitute, this is not a good idea. |
#10 |
no, your first take was correct. Both tweeters need replacing. I dont know what it would cost to get anthony2181's tweeter shipped from the uk but if it is not incredibly outrageous than thats a pair. If its too pricey at least now I know they are not impossible to find.
| Proac tweeter - current model manufacturer | Al.M | Multi-Way | 1 | 1st March 2009 01:41 PM |
| Looking for info onan unknown Tweeter model (M&K brand)? | JBCon | Multi-Way | 0 | 8th December 2008 06:08 PM |
| Tivoli Model 1 FM aerial connector replacement ? | jives11 | Parts | 1 | 3rd March 2007 04:40 PM |
| spice model parameters or better program replacement | mars1 | Everything Else | 0 | 10th February 2004 04:28 PM |
| Replacing tweeter with one from a different model? (Infinity Kappa -> Interlude) | krisztoforo | Multi-Way | 2 | 25th January 2004 03:18 AM |
| Page generated in 0.12740 seconds (72.46% PHP - 27.54% MySQL) with 10 queries |
