Old 3rd July 2004, 05:34 PM   #1
Default polarity of peerless drive units
I'm sure this is a dumb question, but thought I'd better check first:
I'm just putting together a kit from wilmslow audio which uses a peerless 811815 treble unit and a peerless 850812 mid/bass unit. I have soldered the connections on the x-over fine (decent instructions) but before I make the connections to the drive units I wanted to check I was doing it the right way.
The bass unit looks reasonably straightforward - it has a red dot near one of the terminals, so I assume this is the positive connector.
On the treble there is less to see, but there does seem to be a whitish mark near on post on each unit, is this positive as well?
Here's some pictures to help clarify:
Old 3rd July 2004, 05:36 PM   #2
and another
Old 3rd July 2004, 05:39 PM   #3
and one last one, thanks in advance.
Old 3rd July 2004, 05:43 PM   #4
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
You can easily check the polarity of the bass by applying 1 V DC to the terminals and watch the movement of the driver. If the Red dot is positive compared to the other terminal and, the drivers cone moves out, you have the polarity right.
Not sure about the tweeter
Look here for more information www.d-s-t.com
\Jens
Old 3rd July 2004, 05:49 PM   #5
5th element's Avatar
Usually a marking will indicate a positive connection with drive units. It would be unusual I think to denote a connection as negative, usually when this is done both terminals are marked. All I can say do is try and see, use the white as positive and see how it sounds. Im assuming these come with bi wire teminals so it wouldnt be too hard to swap the polarity of the tweeter and see which way you prefer it. I would say though that the white is probably +ve.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 3rd July 2004, 06:33 PM   #6
thanks for the replies guys, that's what I thought really. I'll give it a go. I'm assuming that if I get one driver out of phase with the other it'll be obvious when I try it?
thanks
Owain
Old 3rd July 2004, 06:44 PM   #7
Svante is offline Svante  Sweden
Svante's Avatar
Actually, for odd order filters, both might give a flat response on-axis. Loobing will be different though. If you have a microphone you could try to feed impulses from a computer and look att the waveform from both the tweeter and woofer to see the polarity of the impulses (haven't tried it myself, but it could work).
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Hi Vi drive units cs Multi-Way 3 1st March 2007 06:14 AM
Focal Drive units ANTHONY2181 Multi-Way 1 4th September 2005 06:54 PM
Peerless Drive units ANTHONY2181 Multi-Way 12 5th December 2004 01:00 AM
Polarity of Peerless 53 NDT? sobazz Multi-Way 3 1st November 2003 06:21 PM
Page generated in 0.09268 seconds (74.10% PHP - 25.90% MySQL) with 11 queries
