does anyone have the lambda pb12 sub specs by any chance??
ive searched the old archive on lambdacoustics.com and the link to the pb12 sub actually was the same link to the pb10 if youve used this sub..any thoughts?? |
#2 |
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
I considered the PB12 once (but took the SB12).
This is all I could find on my HD: VAS 160 litre Qts 0.30 Qes 0.32 Fs 21 Hz Xmax 14 mm
Is that all there is? |
#4 |
Here you go:
The Lambda PB12 driver is designed for vented box home use subwoofers and bass-mids. It is a high xmax, stiff poly cone with stiff poly dustcap, coated and sealed foam surround, 12 spoke aluminum basket, dual stack 120oz magnet, gold binding post, military spec coatings and glues. It is a high excursion, very low distortion, super tight bass driver. Recommended maximum crossover point is 500Hz, rated power handling is 500W. Available in 4 or 8 ohm. *Below are specs for 8ohm model, for 4ohm model; DCR = 3.5 ohms, 2.83VSPL = 91.6dB Recommended cabinet of 2.0~4.0 cubic feet vented or passive radiator Fs 21.0 Hz Qms 4.2 Qes 0.32 Qts 0.30 Vas 160 Liters Part# PB10 Cms 0.4 mm/N Size 10" Mms 143 grams Motor PL (overhung) Sd 530 cm2 Magnet 120oz (3.4Kg) Ceramic 5 Rms 4.5 Kg/S VC diameter 51mm Bl 19.5 T/m VC Former Black Anodized Aluminum Re 6.5 ohms VC Wire 4 Layer Copper Flatwire Z 8 ohms Basket Cast Aluminum 12 Spoke Le 0.3 mH Cone Mineral Filled Hard Poly Pe (nom) 300 Watts Cone Profile Straight Pe (max) 500 Watts Surround Doped Foam, 2 layer treatment Pe (transient) 1000 Watts Dustcap Hard Poly "no" 0.44 % Spider Medium stiffness Nomex 1WSpl 88.6 dB Faraday Copper Air Gap 14 mm Pole Vent Yes VC Length 38 mm Terminals Gold Plated Binding Posts Linear Xmax 14 mm (peak) Weight 20lbs Mech Xmax 20 mm (peak) And if its the LE version switch the Le to 2.0 Hope that helps |
#5 | |
thanks a bunch |
#6 | |
Seems these lines from above indicate this is the 10" PB10: Part# PB10 Cms 0.4 mm/N Size 10" Mms 143 grams Actually all the other numbers look about right for a 12" driver so perhaps the 10" figure is just a typo. Also looking for the SAE 1204 specs ... anyone? |
| JBL PB12 replacement amp | Tee-Bruce | Subwoofers | 1 | 18th June 2007 01:59 AM |
| have enclosure, need driver recommendations | talis | Subwoofers | 6 | 2nd January 2007 03:08 AM |
| JBL PB12 dead? | turkish621 | Subwoofers | 10 | 28th May 2005 01:11 AM |
| Help Design Musical Lambda Acoustics PB12-PL Sub | OTMOPO3OK | Subwoofers | 7 | 6th December 2004 04:34 AM |
| JBL PB12 Amp Failure | Galen | Multi-Way | 3 | 28th November 2001 08:01 PM |
| Page generated in 0.12323 seconds (71.49% PHP - 28.51% MySQL) with 10 queries |
