Here is my first crossover that I've designed, it's already been revised from the original copy:
![]() Major changes from the original are the addition of a BSC, and lower cap value on the Zobel. I was hoping to get some opinions about it. Whether it's good, ok, or even bad. Any type of feedback is welcomed. I've asked in other forums and I've gotten replies to lower the resistance value on the BSC to around 4.8ohms. Right now I'm planning to buy a few different resistors for some tweaking. The original is here this: ![]() Thanks again!
Hyman. |
#2 |
Banned
The main thing you want to do is to externally mount the crossover so that you can swap components easily, preferably using screw-terminal binding posts for easy swapping. Don't lose a lot of sleep trying to design the perfect crossover because it can't be done without extensive testing. Joe D'Appolito is probably the best crossover man in the business and he only spends an hour or so at best coming up with a basic design on the computer, and then he spends a hundred hours or so honing the component values down by measuring and swapping until he's satisfied.
| Crossover for vifa 2 way setup - how can I find out what this crossover is doing? | Tino | Multi-Way | 11 | 17th May 2009 04:21 AM |
| Help me with a crossover. | raypalmer | Multi-Way | 4 | 5th April 2009 01:48 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Crossover help please :) | Tenson | Multi-Way | 17 | 15th April 2006 09:34 AM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| Page generated in 0.07310 seconds (68.14% PHP - 31.86% MySQL) with 10 queries |
