Old 2nd July 2004, 06:10 PM   #11
markp is offline markp  United States
Default Re: Its teasing me.
Originally posted by rakeshln
Its the same, 0.62:1:1.62 or 1:1.62:2.62 or 1/x:1:x or x^0:x^1:x^2.
Or x^(n-1):x^(n):x^(n+1), where n is an integer and then applying the Fibonacci rule you get x=1.62.
But, how does this get into dimensions? There has to be some reasoning.
I believe it is because .62 x 1.62 = 1 or .8 x 1.25 = 1 or any ratio like that where the product of the two non-one variables is one.
If it sounds good... it is good!
Old 4th July 2004, 04:25 AM   #12
Still my head.
I dont know how right i am
10log(x)=-1 .... x=0.794
10log(y)=0, .... y=1.
10log(z)=+1, ....z=1.258
10^(-1/10) : 10^(0/10) : 10^(+1/10)
x:y:z=0.8:1:1.26 (approx).
x, y and z look like power ratios to calculate SPL.
Looks good mathematics but nowhere near whats happening physically.
Old 6th July 2004, 02:38 PM   #13
Still my head.
This would not explain why .62:1:1.62 is valid.
Old 6th July 2004, 05:02 PM   #14
Hi markp,
I have no idea. just a wild calculation.
And yes i am the follower of those ratios but everything should have proper reasoning dont u think so??
everything=LS.
Old 6th July 2004, 11:45 PM   #15
GM is offline GM  United States
GM's Avatar
>When considering the Golden ratio also consider the lowest frequency being reproduced. If the wavelength of the lowest frequency is 4 times or more that of the longest dimension standing waves are pretty much a non-issue; in this case that would limit you to an F3 of about 110 Hz, which could be problematic.
???? If a golden or acoustic ratio is used, then it doesn't matter how large or small it is WRT BW since any eigenmodes in all three dimensions will sum into a diffuse pressure field as far as what the driver(s) 'feel'.
>The answer: Put a subdivider inside the box to shorten it internally. If you can't do that for volume reasons then put in a 'shelf' or two that doesn't extend fully across the box interior but does serve to shorten the inside pathway dimension. The additional bracing gained won't hurt either.
Hmm, if you use shelf braces large/dense enough to stop eigenmodes from forming then it will become a multiple chambered reflex with a null at each tuning frequency, like a Karlson, which may or may not be a bad tradeoff depending on the speaker's desired BW and at what frequencies each chamber are tuned to.
I've seen it used in some HT/music rooms I've read about, but AFAIK haven't actually auditioned one. Since it falls within the acceptable ratios defined by the Bolt, Beranek, and Newman graph, I'm confident it works well enough. Really, whether an HT or music room or speaker cab, a truncated golden or acoustic ratio pyramid is the best compromise and why it's a recording studio's, music hall's, and theater's basic layout.
I've only had the opportunity to do one room this way and IMNSHO all these folks who design/build high $$ HTs using rectangular boxes are really 'missing the boat'.
>"....uses the "almost similar" to power calculation ratio of 1 : 1.43 (= 10:7)."
You lost me, which 'power calculation ratio'? Anyway, yes, it falls within the acceptable ratios. One of the more popular room ratios is ASHRAE's 1:1.45:2.10 so will also work well in a wide BW speaker cab.
>Any material on net which supplies proper reasoning?
Do a Google search, there's lot's of info on golden and acceptable room/building ratios from ancient times to present.
Not surprising since it's not practical to try and attenuate eigenmodes, instead using ratios that gets a 3D wave action to create a diffuse pressure field with no strong peaks/nulls.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th July 2004, 03:12 AM   #16
Thanks GM!!
Idea for tall slim B3s design- MMTMM joe carrow Multi-Way 59 27th November 2009 10:11 PM
Thin and tall VS wide and short enclosure limono Multi-Way 2 16th January 2009 09:12 PM
Vented Divider To Cure Standing Waves In A Tall, Narrow Enclosure? kelticwizard Multi-Way 116 3rd March 2008 01:43 AM
Page generated in 0.09614 seconds (73.13% PHP - 26.87% MySQL) with 10 queries
