I modeled and built two enclosures for my DPL12. One is a vented box, 5.35 cubic feet tuned to 16Hz. The other is a 1.5 cubic foot sealed box. The attached graph from WinISD shows the curve for each (yellow is sealed, green is vented).
I suppose I should also mention the group delay... the sealed box has a maximum of 9.27ms delay at 19Hz, while the vented box hits that delay at about 29Hz and just keeps climbing. I have built both enclosures and have them in my listening room and have tested both. However, I cannot make a good call about which to use. Which would you choose? Why? Are there any merits to going sealed over vented or vice versa? Thanks |
#2 |
If they both sound the same to you, then id pick he smaller cabinet, namely cause its going to be easier to move around.
or, you could try a wider variety of music and at various volume levels. See which box makes a difference, and in what way. |
#3 |
Well, they don't really sound the same... but I am thinking I prefer the sealed sub.
My main downfall is that I cannot directly A/B compare on the fly- I have to disassemble one and reassemble the other to test both... so in the downtime, I forget what the first sounded exactly like. |
#4 |
Sealed enclosures will have a slower roll off and therefore sound more "natural". Much better for music, IMO. For a 100% HT sub, vented is great. I've heard the sealed DPL12 and thought it sounded very good.
http://www.alegriaaudio.com/adire_dpl12_subwoofer.htm |
#5 |
I have two, each in a sealed 100 liter enclosure. They were slow and heavy sounding for a while, after break in they just disappeared until low notes come in. They do go low and have all the extension I will ever need.
The freaks stick together, they are a tight old crew |
| Sealed vs Ported (Rythmik) | audioferret | Multi-Way | 3 | 30th December 2006 11:31 PM |
| sealed vs. ported | sonu | Multi-Way | 25 | 9th May 2005 12:50 PM |
| Sealed or ported? | mazeroth | Subwoofers | 13 | 23rd November 2004 12:44 PM |
| ¿Sealed or Ported? | eXn | Car Audio | 28 | 11th October 2004 11:05 PM |
| Adire Audio Dpl12 ported | CarMan | Multi-Way | 1 | 28th March 2003 11:05 AM |
| Page generated in 0.08464 seconds (75.17% PHP - 24.83% MySQL) with 11 queries |
