Goodmans Loudspeaker parts
Old 30th December 2007, 05:18 PM   #11
jives11 is offline jives11  United Kingdom
jives11's Avatar
Default just received a pair of these
I subscribe to my local freecycle list and managed to get a pair of Goodmans Goodwood speakers a guy was getting rid of, for nothing. They now reside in my kids shed/den and don't sound too bad. 3 way as described. They stand about 76cm tall , on the floor and would probably be considered 'dated' or retro in design, but the cabinets are very well made. At present they are being run off a T-amp fed from a CDROM. "Kashmir" sounded suitable bombastic.
One of the bass driver domes has a bit of a dent. Is there a suggested way of returning it to it's original shape ?
Old 30th December 2007, 10:23 PM   #12
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
Hi, Assuming its not actually torn you can often suck the dome back out with a vacume cleaner. It is much easier if you have on with an adjustable suck level. Set it to minimum and then bing the tube close to the dome hopefully it will pull it back out.
regards,
Andrew
Old 4th January 2008, 11:37 PM   #13
Philip_Speaker is offline Philip_Speaker  Canada
Default Tweeter for Goodmans Goodwood Loudspeakers
I own a pair of Goodmans Goodwood Domestic Monitor Loudspeakers. I replaced the tweeters and the woofers in them using parts I bought from Parts Express. I also replaced the speaker connectors with banana plug terminals, bought new cloth for the grills, and purchased a set of ball and socket "grill guides" connectors. The grill now mounts onto the speaker more securely. I hope this helps. Let me know if you have any questions.
Old 7th January 2008, 02:29 PM   #14
Puffin is offline Puffin  United Kingdom
I have a full set of original Goodmans Goodwod drive units that I took out of the cabinets to use them for something else.
Old 23rd January 2008, 08:41 PM   #15
500va is offline 500va  United Kingdom
Thank you everyone for all your help. The speakers have long gone, but replacing the capacitors in the crossover and using some decent tweeters from Maplins made the sound OK.
Kef's Concerto with the B139 bass driver are a massive upgrade from the Goodwoods.
Old 14th January 2010, 06:27 PM   #16
Ivey is offline Ivey  United States
Ivey's Avatar
Default Goodman Speakers: Made great speakers in the 50's and 60's
They bring back nice memories of my parents.
My father was really into HI FI, in the early 60's. He obtained a pair of Goodman Axiette 101 8" single cone speakers/w tweeter, at Goody's Audio Center on West 49th St. in New York. Think it was around 1959, prior to me moving out of their house.
Goodman's Works were located in Wembley, Middx, England, back then.
My dad had this liking for British HI FI gear. His power amp was a 10watt job from a company called Simmons & Sons Ltd. Other than his records, the only other item he had that was not British, was his RCA turntable.
I have his speakers. Not much else remains.
Take Care
Ivey.
Goodmans Loudspeaker partsHide this!Advertise here!
Buy loudspeaker parts in Berlin? jaste Parts 0 4th February 2009 12:13 AM
Goodmans? paba Full Range 3 20th February 2008 03:06 AM
Loudspeaker repair parts Tarzan Multi-Way 0 15th January 2007 07:36 PM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 05:22 PM
