Old 29th June 2004, 06:07 PM   #1
Default Anybody have a cut-away of a tweeter or something...
...else that shows how a tweeter is constructed? Or are they made exactly the same way as all other electrodynamic drivers?
Old 29th June 2004, 10:25 PM   #2
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
I think most are based on the standard electrodynamic topology. Here's some pics of an old Yamaha tweeter...
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 29th June 2004, 11:30 PM   #3
Is that black ring around the voice coil former in the third picture a spider? Do tweeters have spiders?
Old 30th June 2004, 12:02 AM   #4
Vikash's Avatar
Technically I would say it's a surround, not a spider, but yes it does the same job. You don't need both because of the relatively small movement i.e. it provides sufficient restoring and centering force (plus the ferrofluid probably helps too).
Old 30th June 2004, 01:40 AM   #5
Paradise_Ice's Avatar
Some people remove the ferro fluid, they say it helps HF,
but reduces thermal power handling.
I can cut a tweeter in half with my band saw if you like.
Old 30th June 2004, 02:24 AM   #6
Send a message via ICQ to THOR Send a message via Yahoo to THOR
Default cutaway drawing:)
north creek has a cut away drawing of thier top tweeter, look here
http://www.northcreekmusic.com/Drivers/NorthD28-06S.PDF
and here
http://www.northcreekmusic.com/OkaraII/OkaraII.htm
for the special case of the scan speak
If it aint Baroque , fix it !
Old 30th June 2004, 02:24 AM   #7
If you like, but only if it's useless.
Old 30th June 2004, 02:32 AM   #8
Default Re: cutaway drawing:)
and here
Great! Thanks!
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 04:09 PM
Tweeter help for Miller & Kreisell Tweeter 17500 merajsalek Multi-Way 4 3rd September 2008 03:41 AM
Linaeum Dipole Tweeter as a Super tweeter? ktuuri Planars & Exotics 5 17th June 2008 06:52 PM
Round radiating tweeter, aka "Enterprise 1" tweeter! tubee Multi-Way 39 13th May 2007 09:03 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 07:21 PM
Page generated in 0.43246 seconds (24.07% PHP - 75.93% MySQL) with 10 queries
