Hello alltogether!
I’m a complete Newbie (excuse my somehow bad English and my perhaps stupid questions), but I want to built my own bass box (only a box for a stack - no amp!) for my e-bass… (stupid I guess… )Already downloaded WinISD Version 0.44 (don’t like the WinISD Pro 0.50 Alphas – too many bugs in there) and chose some speakers, too. Played a bit around with this one and ended up with questions in mind, ‘cuz the “default” box WinISD calculates isn’t exactly what I’m looking for…. Okay, the data what I want to build (and questions I’d like to ask) :- 1x10” + 1x15” bass reflex box (each speaker in an own cell) - Eminence Gamma 10 for mids + highs - Eminence Beta15/Gamma15/Kappa15 (not sure which makes it in my final design ‘cuz this topic is one where I have some questions left) for basses (I want to get a low b fired out off the box as best as possible) and deep mids - I’d like to tune my box (the 15”) that way down, that its possible to have 35Hz at –3db. o Me doesn’t get this done without getting huge dimensions… o I downloaded the spec sheets off the homepage (already changed the Thiele-Small parameters in WinISD’s database for the relevant models) of the manufacturer and everytime I blow up the recommended size of the box when I try (with every speaker. Even tried with Pro and LF models but happened too)… -> so -> o Is it even possible (without damaging the drivers, getting a good response of the box and without getting muddy or distorted sounds) to get these speakers (and which model of the above ones especially likes that?) down to that (a “how” would be nice)? Or should I look for other models and manufacturers? (advices/recommendations appreciated – they should be built for PA and electric instruments (e-bass) just to have that in mind) o Some other questions: - May I ignore the recommended size specs of the speakers (and to which extent may I ignore that)? - Above which value in ms does the delay start to disturb the experience of the sound – when does it get annoying? - Must be the Tuning frequency of a bass reflex box be identical with the –3db frequency? - To which extend is it possible to “tune down” (the Tuning freq.) a box or is this unrelated to the drivers? (I mean WinISD gives me a value : 48,74 in a 104,6l box for a Kappa 15 speaker – so, how low can I push it without getting crappy sound?) - Yeah, I guess the most questions can be answered by a good book, but hell – I don’t have the cash left for that. Sorry, guys ![]() I guess that’s quite a bunch ![]() But I would really appreciate some help ("forget it and buy a box" isn't a option right now)
#2 |
Tuning frequency for a reflex for low B should be ~ 30Hz.
You can safely tune any alignment given by WinISD with a higher port frequency down to 30Hz. Generally the low port tuning doesn't help frequency response that much but does improve power handling around the port frequency. Given the cabinet is going to be big and you'll have to lug it around compromise hits home with a vengeance. You''ll quickly realise no-one uses hifi type extended alignments with these drivers, the boxes are far too big. sreten.
#3 | ||
Tune to a region which gives a flat or overdamped response Tune to a region which helps power handling Quote:
Efficient,small,low frequency,chose 2 an F3 near 40hz is well good for bass. 4 string extends to ~42hz.. 6string extends to 32hz.. Try Eminence drivers ...often small box with a full low end for guitar bass. 35hz F3,will have to be large.Probably 40hz F3 is good enough/ For example my 2226JBL requires 175Litres and 33hz tuning,the result is overdamped and quality...but the 35hz area is several db reduced...its more optimal to have a 45hz F3 and small box :-) Make sure to read the winisd helpfile. ANd finally before finalising your decision,compare this program with another to be sure . |
#4 |
Thanks guys. Finally I was able to make a "useable" design but one question:
How to improve power handling for my project (for some "fine" tuning)? Sreten says tuning freq. and it did, but what else is possible (except dimensions) and additional or other drivers? @mikee: I read the manual but it didn't cover the info I was looking for ![]() Or at least I didn't find 'em...
#5 |
For "power handling" you need to trade off driver efficiency
versus Xmax of the driver. Simply choosing a lower efficiency driver will improve "power handling", the real issue is max SPL capability in a reasonable cabinet size and driving power. sreten.
#6 |
Banned
Two points. First, forget about F3 at 35 Hz because you just don't need it. The maximum output of the electric bass takes place in the second harmonics, not the fundamentals, and a speaker capable of running to an F3 of less than 60 Hz is just not required. As an example an Ampeg SVT F3 is 60 Hz.
Second, don't duplicate so much range with your drivers. The fifteen is quite happy up to at least 800 Hz, the ten is good down to 100 Hz- that's a lot of overlap. Put more money into the 15 where you need it and go with an 8 for the high end. A Gamma 15 and Beta 8 makes a lot more sense. |
#7 |
THX sreten for your "real issue"-explanation. Just what I wanted
Okay, already forgot the F3 at 35hz - now its around 45hz for the Gamma 15 cell... ![]() I thought I could handle this huge overlap with a freq.-switch (freestyle translation for German Frequenzweiche - but I guess you guys get the picture ![]() ).... 'cuz a 10 has more power in mids than an 8.... and I don't like highs that much.... and I don't need them much...so I thought the 10 would handle that in a sufficient way.That should be a bass box designed for Death Metal, so no need for highs (but for basses and (deep) mids ![]() |
#8 |
TBH IMO a Gamma 15 will not benefit much at all with an added
10", and will soak up amplifier juice without giving a lot in return. The Gamma 10 will not work well with the Gamma 15 due to the difference in sensitivities and will half the cabinet impedance, some capacitive filtering is also needed to prevent bass overload. The Alpha 8MR is a much better idea and as this would use a 1st order filter set at ~ 1KHz would not effect cabinet impedance. A plain 2x15 or 4x12 is possibly a much better idea IMO. sreten.
#9 |
Oh man.....
Building boxes is more complex then I thought.... As a total noob I guess my idea is just a plain overkill (would be my first box though...), cuz it seems impossible to build that without knowing the more complex tricks of PA systems....(filtering and stuff) ... So I better get back to some standards I guess (at first - muhaha I WILL RETURN
| Bass Exciter build | dublin78 | Subwoofers | 1 | 25th September 2007 02:10 PM |
| I want to build my own ALL TUBE bass amplifier | juicy1484 | Instruments and Amps | 1 | 2nd November 2005 08:15 AM |
| Want to build bass cabinet for Fender BXR 300 | timzog | Multi-Way | 14 | 11th June 2004 12:50 PM |
| how to build a bass bend/scoop cab | Javalon22 | Subwoofers | 1 | 5th January 2004 05:28 PM |
| i wanna build me a bass amp | badger | Solid State | 10 | 27th December 2001 03:02 AM |
| Page generated in 0.28145 seconds (45.56% PHP - 54.44% MySQL) with 10 queries |
