#11 | ||
lol
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#12 |
Streten,
I actually have Sound Check 2! I'm not sure how to get anything useful from the pink noise and warble tones though... The sine waves seem to make good sense, and now that I have a CD of them I can properly hunt down the troublesome rattles! Some I won't be able to fix though, such as the entire plaster dividing wall behind me wobbling at 34hz...
#13 |
Huh ?
Use the 32 pink noise bands with your sound level meter, and plot the frequency response at your listening position, (and several others over an arc if you have the time). Using my ears the sweep tones are easy for spotting problem areas and the 1/3 octave bands great for identifying the frequencies of the problem areas, if you can't hear discontinuities with the 1/3 octave bands, then simply put they are not there. Tracks 34 and 35 are the quickest tests, but only really bad problems are immediately apparent over these. sreten.
#14 |
Ah, ok. Will try the 1/3 octave bands next. Thanks.
It looks like I have found the culprits of two peaks already - my internal width is 19cm - which is half a wavelength of 890hz - this is right where my biggest peak is. There is one much less important one at around 370hz, which possibly comes from the height of the stand section. http://www.mcsquared.com/wavelength.htm (actually, GM pointed this out, and I'm grateful to him) Now, how much is coming from the open stand section, and how much from inside the working enclosures? I have some 18mm ply (just made a cdp platform with some) and some 6mm MDF, and some 18mm MDF. So I can get to work on closing the stand section - just closing it on the front should work AFAICT. And if I attach plywood it should alter/improve the resonance of the speakers, presently being just MDF. My question now to anyone reading is: how can I alter the 900hz/speaker width resonance inside the speakers, without reducing the liveliness of the presentation? How about attaching a thin piece of wood to one side at an angle, so as to spread the resonance evenly? Thanks for reading and suggesting!
#15 |
Simon,
I suggest you move your microphone a bit while measuring. If the microphone is fixed, it is normal in a room that you get ripples. But if you can move the mic around a imaginary sphere of approx 1 or 2 foot diameter, then, some ripples will disapear... magic This method is better for measuring in room. F |
#16 | |
I've just sawed a coupla bits of pine to form baffles for the stand sections of the speakers. I also put a cushion in the cavity of each one. I held my meter steady and tried 900hz at the same level as before and compared it to the frequencies above and below... and the peak seems to have gone down by 1-2db!
#17 |
I find my bass response a tad thick, could a highish level at 140hz-230hz cause this? Or maybe it's the peak at 85hz.
When I listen I hear the thickness in the mid-bass region - 45-65hz is what I keep thinking it sounds like. I can't easily relate the character of sound I hear to the measured response!
#18 |
Sorry for my english... it's not so good
repeat your measurement in an anechoic room or at least in a wide open space and you shoul obtain a linear reponse but any peaks or gaps in the frecvency can be corected by equalizers try http://www.linkwitzlab.com/ ... you can find a lot of good ideas here about how to minimize thye standing waves in your room... unfortunatelly i don't have the resources to build such things but I have tried using other drivers and i'm pleased... they sound much better but their spl lack dissapoints the bass freaks but you can alweays use a conventional sub |
#19 | |
I'm not looking to use EQ either, until I'm rich (haha) and can afford one of those fancy DPS boxes, and to tri-amp ie only eq the bass section. I've worked out the cause of all the serious peaks and dips now and am considering how to improve things. I will try to report back with an improved curve soon! My dip at 125hz is, I believe, a null of the F3 of length. This should be more like 135hz, but as the rear wall is plaster-board, the effective room length is longer I believe. That's the only explanation for the dip I can think of. Just need to try and not sit too far back to avoid this dip! I've always preferred it closer to the speakers/out from the rear wall. The dip at 70hz is from being near the middle height and width wise, so at the F1 null for those two - which are nearly the same distance I don't think there's anything I can do to fix this - the room is too small for manouvre.
#20 |
it's not so difficult... use some good quality op-amps to adjust the gain...use some filters so the effect will be heard only at a specific freq
it's a good ideea to use variable filters so you can make small adjustments its the cheapest&simplest solution possible |
| Frequency response | 2litre | Analog Line Level | 5 | 31st May 2006 07:00 PM |
| frequency response | pmarcouxx | Digital Source | 2 | 20th July 2005 07:43 PM |
| opt frequency response | nkg | Tubes / Valves | 3 | 29th August 2004 06:31 AM |
| Doubts on Phase Response and Frequency Response | dumrum | Multi-Way | 11 | 5th April 2004 10:39 AM |
| frequency response of air | mikelm | Everything Else | 8 | 29th February 2004 07:17 PM |
