Offset driver - Fostex 206E in Open Baffle ?
Old 28th June 2004, 05:42 AM   #1
Steve M is offline Steve M  Australia
Smile Offset driver - Fostex 206E in Open Baffle ?
Just a quick question, should a speaker driver mounted in an Open Baffle be mounted off-set towards the inside edge of the baffle??
Does this inside edge off-set arrangement assist with imaging like it does in multi-way speakers?
My proposed Fostex 206E Open Baffle design has a surface area of 2' x 4' x 6" wings, and I may mount a Fostex FW405 in this baffle or go Bass Reflex for full-on bass in the future.
Thanks in advance...
Steve M.
Old 28th June 2004, 12:27 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
The driver should be slightly offset - I don't think it matters too much if it is to the inside or outside but you can always swap the baffles over and try both!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 28th June 2004, 01:27 PM   #3
R.I.P.
http://www.diyaudio.com/forums/showt...409&highlight=
Note that due to its low Q the FE206E will have very restricted
bass before you even consider the additional baffle roll-off.
sreten.
Old 28th June 2004, 02:52 PM   #4
Thanks Nuuk & sreton, I will apply the 0.8:1 or 0.6:1 ratio for the driver offset.
Sreton: I am not expecting great bass from the 206E. From what I've read extensively on the net I don't think these type of single drivers do a lot of bass. Having heard the 206E in a 20L bass reflex box optimally loaded using WINISD, there was not any strong bass to speak of.
My intention to use this driver either in a BR box or open baffle is to enjoy it's electrostatic like imaging qualities, and the immediacy and coherence that only a point source single driver achieves. Proper and deep bass will be sorted out later either using a dipole/TL subwoofer or a properly tuned BR box of about 180L with something like the 16" 96dB Fostex FW405 woofer.
With respect to the off-set driver question, did you notice a big difference between offset vs. central mounting on the baffle, and what was the qualitative difference sound wise?
Steve M.
Offset driver - Fostex 206E in Open Baffle ?Hide this!Advertise here!
Open Baffle offset PeteMcK Multi-Way 7 14th May 2015 02:27 AM
Open Baffle Desktop - Fostex 4 angeloitacare Multi-Way 2 8th June 2009 10:49 AM
Fostex 206e baffle hole size ljk11 Full Range 2 3rd January 2009 09:01 PM
Fostex FE207E with Eminence Alpha 15 open baffle sharpi31 Multi-Way 15 21st September 2007 03:20 AM
Fostex 206E/103E + Raven R-1 Ribbon + Dual 12" Yamaha Neodynium Open Baffle Speakers Steve M Multi-Way 4 28th July 2004 02:19 AM
Copyright ©1999-2017 diyAudio
