Account Disabled
Last weekend I noticed that my left speaker has extensive veneer bubbling. The veneer was applied only 3 months ago using the "PVA wood glue on MDF and veneer-wait for both to dry-then iron on" technique. :-)
It must be due to the heat because every afternoon sunlight comes streaking through the glass sliding door into our living room and falls directly onto the outer surface and top of left speaker. At first I wasn't very concerned but now both these surfaces are have bubble extensively. Does anyone has ideas of how to fix this? Ordinarily I'd just re-iron out the bubbles, but the problem is I've already oiled and waxed (Danish oil and fine paste wax) the speakers. Please help! |
#2 |
I have an idea that may work.
Get a syringe with a very thin needle. Take in some PVA glue ( if required thin it down with a bit of water if it is hard to expell it through the thin needle. Better if you use quick set PVA glue ( wood glue) . Poke the veneer carefully (along the grain) and inject a small quantity of glue. Then press the area very hard .. maybe some clamp ... and wait for a day for the glue to set. This might work. Instant glue could work also I guess. Use pvc gloves to avoid any accidents and work FAST. Just some ideas. I've never tried it myself. Cheers, Ashok.
AM |
#3 |
Banned
Even if you fix the problem the source is likely de-gassing of the layer below the veneer. Trapped moisture below the veneer could also be the source. What it the box made of? If it's a composite material de-gassing could be a long term situation, and you may never be able to leave the speakers exposed to sunlight.
This points out a deficiency of using a water based glue for veneer; such problems are less common when a solvent base contact cement is used. |
#4 |
I have used contact cement and still got extensive bubbling. I will have to try the needle method.
| ARGH! One channel failed ... where to start? | paulspencer | Chip Amps | 1 | 23rd July 2007 12:44 PM |
| argh what site was this! | neutron7 | Everything Else | 7 | 18th February 2007 07:13 AM |
| Argh!! | phn | Tubes / Valves | 12 | 4th November 2006 02:23 PM |
| Argh | Otherwise | Everything Else | 1 | 10th March 2004 07:28 PM |
| Veneer on veneer?? | sam9 | Multi-Way | 5 | 1st August 2003 06:21 AM |
| Page generated in 0.07617 seconds (72.87% PHP - 27.13% MySQL) with 10 queries |
