i want to stick a really tiny tweeter to the pole piece of
a Vifa P13, or maybe like the hammer 12? Xo is to be frirst or second order @5 to 7K. Yeah, yeah ,I know i just need to try this Or maybe stick a pieazo element to the dust cap? I already have the p13s from an old project, doing nothing. I listen Near Field , so I want it concentric.Anyone know of a good tiny one? maybe i could call it "the tackhammer 5" LOL
If it aint Baroque , fix it !
#2 |
You might try the Audax TM010A1. It is the best small tweeter i have heard I used 2 in my car because space is tight and I am very pleased with them. They are about 1 1/8" in diameter and are the perfect shape to mount on a pole piece. You might also try the TM010A39 which is a slightly larger 8 ohm version. You can find both at www.madisound.com
#3 |
Hi Thor, what about the Audax TM010A39? Madisound has it for 12.95.
#4 |
thanks for bringing this to my attention
the FR looks really good, and its also shown out of its housing, looks to be maybe a 1/2" the dome is about .4" im going to try this crazy idea Since I HATE XOs the plan is to let the p13 assume its natural smooth roll off. it looks to be -3 @5K and -6@7K. so a paper in oil cap (also left over at 5K would match or a cap and inductor down 6 db@7K, if 6 db dosent cut it off fast enough. I actually listened to the p13 by its self for a few months, but finally the missing high end got to me. This is a very smooth little driver, extremely well behaved and ruler flat from 100 to almost 5K
#5 |
The P13 was built for maximally flat freq. response.
...still looking for the holy grail. |
#6 |
The little gold Audax TM010A7 is the best of the little Ts. The TM010s are typically used 1st order at 6-7k or so. The ApexJr version also isn;t bad and is probably the cheapest... picture is of one i carved the ears off of.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Here is a snippet on the TM010A7... they might be hard to find thou -- you aren't getting mine :^)
dave
#8 |
Banned
Check out the closeout Onkyos at Parts Express. Already pole mounted. I used 24 of them in a pair of line arrays, very flat from 6kHz to 20 kHz. You can afford a few of them at $0.37 each.
#9 |
I would prefer the Vifa PL27TG-35-06, if it comes to that point. Try to have a look on the data sheet...
Parts Express #264-527 Greetings, B.
JayBeeOnline.de |
#10 |
where did you get these dave? how much? They are perfect. Ill also try the PE269-782 3/8" neo @ 32cents ea
thanks to all of you for the help ![]()
| The Tiny Pre Amp | uhcmos | Swap Meet | 13 | 8th August 2008 11:16 PM |
| Tiny, tiny DC-DC converter | jackinnj | Power Supplies | 1 | 28th June 2006 08:03 PM |
| tiny amp | vlljpior | Tubes / Valves | 6 | 9th July 2004 07:42 AM |
| Tiny amp | lifeonmars | Pass Labs | 4 | 12th December 2003 10:13 AM |
| Page generated in 0.09798 seconds (82.38% PHP - 17.62% MySQL) with 11 queries |
