Old 26th June 2004, 10:56 PM   #11
planet10's Avatar
Default Re: Hi Dave. TM010A7
Originally posted by THOR
where did you get these dave? how much? They are perfect. Ill also try the PE269-782 3/8" neo @ 32cents ea thanks to all of you for the help
I bought them about 6 years ago from Martin Sound, i think they are discontinued, but some calls or emails to Audax distribs might turn some up ... i just looked in the Solen price list and they have a TM010A39 which could be a close relative -- looking on their website it is listed as a TM010A7 and the pic looks right.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th June 2004, 11:47 AM   #12
derf is offline derf  United Kingdom
derf's Avatar
Default Could this be the makings of an ultimate point source driver?
If this is pulled off, it seems it could be pretty much that
It has the flat response of the P13 in it's favour, low order crossover outside the formant range, less beaming of high frequencies, probably a far flatter response than any affordable full/wide range driver
Most commercial Coax speakers I've seen have been big 15" units crossed over at about 1khz, tbh I've not actually heard any of these drivers, so they could be great, but the crossover is still in a sensitive part of the frequency range as far as I can see
I'm sure there are plenty of extended range drivers that could be used with a mini tweeter in such a way
I'm reasonably new to this forum and DIY audio on the whole, so all the above is just my own personal opinion and isn't really founded on much experience at the moment, but like somebody else recently posted, some people like to understand the workings behind speaker design before throwing themselves into the fray
I'm sure there are plenty of issues I've missed out, and some things I may even have got a bit wrong, but I've got no problem in someone politely correcting me and explaining where I've gone wrong in my analysis
It's all a learning process
Old 27th June 2004, 06:23 PM   #13
Send a message via ICQ to THOR Send a message via Yahoo to THOR
Default hello Derf...
yes you are right IMHO. those are the reasons i need to try this I listen near field (43") and if the tweeter is remote from the center of the P13s , in that distance, the wave fronts do not coalesce into a cohesive whole and you are listening to a speaker that sounds split. very bad! ive tried 1" domes , Stryke Planars , and cheap mini tweeters(broke them)and NOTHING worked. MTMs are the very worst. I currently use Jordan JX92S FR and they are splendid, but $290 for a second pair will break the bank (literally, as Im retired) and I already have a lot of stuff left over from many previous builds, including the p13s and really good vintage paper in oil caps i got from Bruce Edgar, and everything for the subs . I do hope that the "TACKHAMMER 5" turns out to be as good as i expect removing the soft dust cap from the P13 was a breeze I will, of course, use them with a sub
If it aint Baroque , fix it !
Old 27th June 2004, 06:51 PM   #14
derf's Avatar
A little more information on how you plan to mount them would be nice, you intend to put the magnet of the TM mini tweeters inside the pole piece of the driver, right?
If so, won't the two magnets repel each other?
Also, what are you going to do about the cable connectors(do they fit inside the pole piece) and running speaker cable out to the amplifier?
Drill a hole in the back of the p13's magnets maybe?
Old 27th June 2004, 08:26 PM   #15
planet10's Avatar
I'd approach it like PHY-HP has -- putting the tweeter (in their case a naked piezo) on the end of a cylindrical phase plug. This is the best pic i could get from theire site:
I wounldn't even attempt that. i'd just run a pair of 30g solid over a "post" on the side(s) of the P13 high enuff above the cone so at max excursion the cone doesn't hit the wire.
dave
Old 27th June 2004, 11:09 PM   #16
derf's Avatar
Default Opinions
Dave, what are your opinions on this particular design in comparison to a standard full range design in the same price bracket, strong points, weak points etc
I know you're quite well versed in all things full/wide range and that you sell a lot of vintage full range stuff, so your comparisons of these two slightly different ways of going about things would be well received
Would it be possible to time align a tweeter in such a configuration, do you think this is of much matter?
Have you ever attempted anything of the like yourself?
Old 28th June 2004, 06:31 AM   #17
Default mounting and connections
depending on how the magnets are polorized they may attract. if not, ill epoxy them to a small piece of wood and epoxy that to the pole. For connections, ill drill 2 tiny holes thru the baffel , run a piece of magnet wire thru it from the back and arch it up, over and down to the tweet like a "Daddy Long Legs". I saw one in my shop today which gave me the idea Tomorrow i order the tweets , but Solen has a lot of crap on thier site about tax, brokerage fees and duty . if its too messy or expensive ill get the ones from Mad, but I REALLY wanted the neo ones . The Mad ones are the gold domes but they dont mention thats its neo or not. Anyone from the US bought stuff from Solen?
Old 28th June 2004, 07:32 AM   #18
planet10's Avatar
Default Re: mounting and connections
Since you are ordering from US there should be no tax, make sure they send them expedited post -- they are cheap enuff they will probably sail thru any customs even if the US charges duty on new French hifi product.
dave
Old 28th June 2004, 07:42 AM   #19
planet10's Avatar
Default Re: Opinions
The local dealer brought in a pr of these... they are exquisite in build... when i 1st heard them i thot they had promise. Leter i heard them in another room and they (the system in the less than stellar room) sounded terrible. I'd like to hear them in my own room.
At 3.5k$/pr they are not cheap, so there are a lot of other top-notch drivers in competition... Exact, Supravox, Fertin, Lowther
Not i think, without some active or digital delay
Have you ever attempted anything of the like yourself? [/B]
Not yet... similar projects are in the queue...
dave
The Tiny Pre Amp uhcmos Swap Meet 13 8th August 2008 11:16 PM
Tiny, tiny DC-DC converter jackinnj Power Supplies 1 28th June 2006 08:03 PM
tiny amp vlljpior Tubes / Valves 6 9th July 2004 07:42 AM
Tiny amp lifeonmars Pass Labs 4 12th December 2003 10:13 AM
Page generated in 0.13220 seconds (79.99% PHP - 20.01% MySQL) with 11 queries
