Hi all
One thing isnt clear If i use a 15" adire tempest for example, on 115Litres tuned to 33hz, Then use Parametric -5db gain,Fc=50hz,Q=0.4 EQ.. this results in a flat response. BUT transient response must equal what the final FR is yes? with a flat response i expect good quality bass,not quite overdamped control,but 'okay' i certainly dont like the underdamped peaky box,which is why i thought about applying EQ. btw with this alignment it can handle 750watts easily,xmax peak in midbass only 8mm..ofcourse subsonic filtering would be best to keep it safe below 25hz. ---just in theory--- Cheers! |
#2 |
diyAudio Moderator Emeritus
Mike,
I would expect the transient response would be that of the box alignment even though the total response is flat. I run an over damped alignment with electronic bass boost.
Rodd Yamashita |
#3 |
Did it Himself
I think that because the box is a 4th-order system and you are skewing the frequency response with a different order response, i.e. are not exactly cancelling/moving the poles and zeroes, then the transient response is not properly improved.
However, the bass sounds better because of the reduced amplitude exaggeration. |
#4 |
The transient response will theorectically ~ be the same.
The end result is a FR and TR not normally available from the driver, but it will be nearly equivalent to another driver with that alignment. (some minor ripple difference is to be expected) |
#5 | |
Rodd Yamashita |
#6 |
Well if it wasn't right the Linkwitz Transform would be a non-starter.
But I'm not saying it is the same in all respects, port utilisation would be different and low bass power handling affected by this. |
#7 | |
Rodd Yamashita |
#8 |
The Linkwitz Transform also converts the transient response of
an underdamped sealed box to that of the target TR and FR. The same applies to a second order notch filter applied to an underdamped 4th order reflex response, both FR and TR. I don't think it works well in practise due to effects at high levels. |
#9 |
thanks guys for clearing that up!
#10 | |
the LT or the notch filter doesnt work well at high level? |
| Controlling transient response | AdamZuf | Tubes / Valves | 29 | 6th July 2007 01:38 AM |
| Best vented transient response | rick57 | Multi-Way | 18 | 27th December 2006 05:24 AM |
| Transient Response: Sealed v Dipole | rick57 | Multi-Way | 4 | 12th December 2006 05:26 AM |
| Transient Response Testing | cm961 | Multi-Way | 37 | 22nd March 2004 09:57 AM |
| EBS transient response | Solid Snake | Multi-Way | 1 | 1st February 2004 05:26 AM |
| Page generated in 0.13246 seconds (68.69% PHP - 31.31% MySQL) with 11 queries |
