#1 | ||
This is a contination of the thread started here so that I don't threadjack other threads.
Here's the response to this message: Quote:
The Chromium plated screws I got from this small shop right at the other end of SP road (I forget the name, sounded like a Muslim name). The owner is a nice guy, when I mentioned I wanted something "better than ordinary" to use in a speaker box, he got me these and a couple of others.Quote:
The tweeter's fine, far more efficient than the woofers! I had to pad it down almost 10dB before my ears stopped hurting! I've built a 12dB/oct crossover, and I've used ferrite ETD cores from Siemens, gapped to prevent saturation. I've measured their inductance at home using Speaker Workshop and an impedance jig, so the power through them during measurement would have been quite real-world. When plotting an impedance graph, the only deviation from ideal was way up at 18kHz, and at those frequencies , firstly I'm deaf, second, Speaker Workshop's test signal and algorithm introduce some junk. I will try and do "proper" saturation tests on them to see if I can find any problems (ie, apply some DC current, with the AC test signal riding on top). The result of using the ferrites is that the whole crossover fits in the palm of my hand |
#2 |
I am researching the MTM and 2.5 way theory to see which is the better option to try out.
Vivek
Thank God for DIY audio. |
| 3 Way floorstanders | jjbmon | Multi-Way | 3 | 26th January 2008 08:45 PM |
| My new floorstanders- | nate | Multi-Way | 13 | 31st October 2006 02:27 AM |
| 300 a pair floorstanders | bjackson1 | Multi-Way | 0 | 19th June 2005 07:10 AM |
| JV80 floorstanders | jose-emenace | Multi-Way | 2 | 14th June 2005 12:59 PM |
| Dayton Floorstanders | greg_mcquaid | Multi-Way | 3 | 30th May 2004 03:14 PM |
| Page generated in 0.08852 seconds (65.30% PHP - 34.70% MySQL) with 10 queries |
