#11 | |
With that in the back, and two spikes/cones/whatever in the front (baffle) you can easily adjust the speaker at will. I'd also consider a shelf connected to the baffle, as extra support for the TAD |
#12 |
I'd suggest two trapzeoid shaped wings on either side, ie X (the height), 20cm (the top), 40-60cm at the bottom, and then do a horizontal cross brace below the horn to support it and give a solid structure.
It would have the dual benefit of supporting the horn and extending the bass, without knowing how you're planning on EQing. Cheers Steve
http://cargocollective.com/stevedodd...ge-of-the-Nerd |
#13 | |
Banned
#14 | ||
#15 |
Some attenuation (and slowing) of the rear wave helps make near wall placement more possible.
With transparent wings, I'd go with a single relatively thin pole with something at the top to cradle tweeter, like the non-tripod supports that sports photographers use. That's as long as there aren't kids or dogs that could knock it over. If there are, you are going to need a support that goes quite deep since the baffle will be so top heavy. Also, you don't want spikes or cones. Don't give up the free ride that the baffle/floor junction gives you.
Everyone has a photographic memory. It's just that most are out of film. |
#16 |
Based on my own experience with my open baffle speakers I would say make the baffles a bit wider.
Mine are 104 cm high by 83 cm wide and go down to around 70 Hz with the Goodmans 201's. As regards placement, they sound better the further away from the rear wall that you can take them. Mine are about one metre from the rear wall and sound better there than at 60 cm. For most of us not living in a palace, there is a limit to how far out into the room we can bring them so there will have to be some degree of compromise. I made up some absorbant 'bags' of offcuts of foam to place behind the main drivers which also helps!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#17 |
If you can make the dipole to front wall the same as the distance from the listener to the rear wall it will give a first reflection cancelation at low freq. linkwitzlab.com FAQ 31 LS |
#18 | |
Banned
How about hanging it from the ceiling?
Are you going to biamp or choke the TAD way down? Quote:
| Designing for on-wall/near-wall speaker placement | morbo | Multi-Way | 4 | 27th November 2010 04:52 PM |
| in-wall/on-wall speaker? (axiom w-22 clone?) | Scott_fx | Multi-Way | 0 | 22nd February 2007 02:08 AM |
| dipole midrange or subwoofer, distance with wall ? | mbon | Multi-Way | 34 | 2nd August 2004 06:26 AM |
| Dipole sub for wall placement ? | phase_accurate | Subwoofers | 1 | 18th June 2004 06:20 PM |
| Opinions on wall to wall subwoofer array | jmiyake | Subwoofers | 35 | 19th July 2003 11:26 PM |
| Page generated in 0.26902 seconds (29.77% PHP - 70.23% MySQL) with 11 queries |
