How is the effective piston area of a cone calculated? How is the effective piston area of a cone calculated? - diyAudio
Old 21st June 2004, 07:57 PM   #1
454Casull is offline 454Casull  Canada
Default How is the effective piston area of a cone calculated?
It probably isn't pir^2... Anybody know?
Old 21st June 2004, 08:06 PM   #2
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Usually the diameter is measured as the actual cone diameter plus half of the surround on both sides. Then it's pi X (dia/2)^2
Rodd Yamashita
Old 21st June 2004, 08:51 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
Yes, it is:
Sd = pi * radius ^2
or, since radius = Dia/2
Sd = pi*(Dia/2)^2 = (pi*(Dia)^2)/4
As Rodd says, you should include half of the surround. The easiest way to measure diameter is to measure across the diameter on opposite sides of the surround. See picture.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
How is the effective piston area of a cone calculated?Hide this!Advertise here!
Do You Have an old Blown Percision Power PPI 12 inch flat piston? newtothis Car Audio 1 11th June 2015 06:15 AM
Cone weight vs Cone stiffness musgofasa Full Range 9 25th July 2008 08:16 PM
How can I find effective piston area? mstar Multi-Way 14 22nd June 2006 05:50 AM
What's the effective delay ? Will Multi-Way 8 26th March 2006 06:45 AM
Copyright ©1999-2017 diyAudio
