Old 21st June 2004, 05:48 PM   #1
Default question about driving single VC sub.
Can i drive a single VC sub on stereo? What i know is there is no stereo low down. If yes, how is the impedance and power rating done?
Old 21st June 2004, 06:54 PM   #2
Banned
Can you drive it with what? Do you mean from a 2 channel stereo amp without a separate amp for the sub? If that's what you mean then yes, you can, but you have to construct a passive crossover to direct the low frequencies to it and away from the main speaker, which will preserve the proper impedance values. There is no true stereo down low from the standpoint of the ability to discerne directionality, but many older recordngs did pan LF information, so if you have the sub on one channel only you won't get any bass in some cases. It's best to have the crossover a LP summing configuration that hooks to both amp channels to get signal from both sides, and once you investigate the price that the necessary components will cost you'll find that you'd be better off to buy a plate sub amp in the first place.
Old 22nd June 2004, 01:38 AM   #3
This is the very first post I ever made on diyAudio. It deals with this issue:
How To "Bridge" A Stereo Amp to Just One Channel
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Driving differential ADC with single-ended source suzyj Digital Line Level 9 19th May 2009 07:39 PM
Driving a 6B4G with a single 5687/7044/E182CC? G Tubes / Valves 2 6th May 2007 11:29 PM
Quick Question (Driving 6L6GC's) sorenj07 Tubes / Valves 7 17th April 2007 03:26 PM
Driving a single 6L6GC with 12AX7 mrhotmark Tubes / Valves 10 18th November 2005 02:58 AM
DRIVING Aleph 5 - quick question?? D3 Pass Labs 2 2nd December 2003 07:09 AM
Page generated in 0.09122 seconds (64.90% PHP - 35.10% MySQL) with 10 queries
