Old 21st June 2004, 10:20 AM   #1
Default atc sm75 and hiquphon ow II
i came about the idea to use the atc sm75 and hiquphon ow II, yet I am a little bit concerned about polar pattern response behavior due to a >3k crossover point.
this will be an active 24dB project.
afaik the atc 75 needs a 154mm hole to be mounted in and the owii is 92 mm, therefore a minimum at 30 degrees can be expected at 2750 hz.
my question would be:
what do you think of that combination?
what crossover points are you using for the atc?
how close can you bring any tweeter to the atc, before havig problems due to the two magnet systems?
not related to this, but, is there any benefit using the s version, when i am usually listening to levels not exceeding 90dB?
thanks for your answers
I appreciate any comment
regards
leif
ATC SM75-150S+R2 or ESG1 Selfmade Multi-Way 17 2nd May 2011 09:57 AM
For Sale: 2 x ATC SM75.150S dkxdn Swap Meet 8 17th July 2008 10:26 PM
xover for atc sm75-150s montana Multi-Way 2 8th July 2007 06:25 PM
ATC SM75-150s x-over design help? T-Dot Multi-Way 2 4th January 2007 09:02 AM
Fs: Atc Sm75-150s triode4 Swap Meet 1 7th September 2006 02:55 AM
Page generated in 0.07081 seconds (72.94% PHP - 27.06% MySQL) with 10 queries
