1)Is it better to have the crossover outside the cabinet?
Not just for being able to get at it, but for the curcuit itself etc. 2)Is it best to have a short run of interconnect and a long run of cable? Or a long run of interconnect and a short run of cable?
'I have nothing. I owe much. The rest I leave to the poor. - Francois Rabelais satirist & doctor d.1553 |
#2 |
Banned
The advantage to having the crossover external to the cabinet would be the additional distance of the inductors from the drivers, which would reduce cross-talk.
Keep the interconnects as short as possible, the speaker cables long. Interconnects are subject to noise pickup, which is then amplified. Any noise picked up on the speaker cables will be less audible and won't be amplified. |
#3 |
would mounting the crossover on the back of the cabinet make any difference? Or would placement on the floor or some other surface be best?
#4 |
Banned
For the sake of convenience the cabinet back is best, located as far as possible from the drivers. Another option is below the box in a separate sub-enclosure, especially if it's a floorstander.
#5 |
How about if my pre has a balanced output? could I then mount the amps inside and not suffer ill effects?
#6 | |
#7 |
being a newbi I sometimes have trouble telling an 'in' joke from a valid comment.
I have optical outs I could use. Any good?
#8 |
Banned
YOu could make mono block gain clones and put them into your speakers that would work pretty good.
#9 |
Guess what I have comming from Peter Daniel in Canada?!?!?!
How about a mono block gainclone in a Tannoy Berkerley?
#10 |
Banned
WEll one of my ideas here soon is to build a few versions of these gain clones since i have about 8 chips.. One is powered active speakers then a pair of stereo mono blocks for bi-amping.
| The Loud Speaker Kit May Specials | LSK | Vendor's Bazaar | 0 | 21st May 2009 01:56 AM |
| make your own loud speaker. and I mean it | metalinspired | Multi-Way | 12 | 24th September 2005 01:10 PM |
| speaker placement | The_Hi_End | Multi-Way | 3 | 4th August 2004 06:55 PM |
| loud speaker 6 ohm resistance | petros | Multi-Way | 1 | 29th December 2003 05:27 PM |
| Page generated in 0.15371 seconds (57.54% PHP - 42.46% MySQL) with 10 queries |
