Old 20th June 2004, 03:39 AM   #1
mbon is offline mbon  France
Question multi amplification and different sensitivity drivers : drawbacks ?
Is there any drawbacks to use drivers that have very different sensitivity in a three way active loudspeakers...?
Sample :
trebble : compression driver B&C DE25 108dB/w/m
medium : SEAS-W22EX001 87 dB/w/m
bass : Beyma 15LX60 98 dB/w/m
trebble unit require less than 1 watt to work loud
medium unit require 60 watts to reach the same trebble SPL
bass will require also 60 watts due to the needed equalization (will work sealed)
Is this a good idea to use high sensitivity trebble unit (i've heard DE25 is great, crystal clear, detailed, smooth & dynamic) ????????????????
are the first 0.5 watts of amplifier good enough ?
I've read that it was not a good idea to use different amplifier in a multi active loudspeaker design, is it true ? Why ?
Old 20th June 2004, 05:08 AM   #2
Bill Fitzpatrick's Avatar
Default Re: multi amplification and different sensitivity drivers : drawbacks ?
It's a good thing according to those who say even excellent amplifiers sound different. You can choose an amp that excels in bass for the woofers, etc. Even Nelson pass admits that one (or more?) of his amps has an edge in the low end.
One scenario might be; a flea powered class a for a high efficiency tweeter, a class a/b mosfet for the bass and, perhaps, a tube amp for the mids.
Old 20th June 2004, 05:51 AM   #3
Default Re: Re: multi amplification and different sensitivity drivers : drawbacks ?
Yes but what about amplifier gain ? When pushing up the volume, every amplifier must follow with the same balance !
Is it always true ?
Old 20th June 2004, 07:04 AM   #4
The gain problem can be solved in the electronic crossover or with pots at the amp input.
Old 20th June 2004, 03:16 PM   #5
Banned
In fact, using separate amplifiers with electronic crossover is the only logical way to use drivers with sensitivities so different; otherwise you'd have to resistive pad not only the tweeter but the woofer also, which is never a good idea.
Advice sought on building multi-channel amplification jwillans Solid State 10 3rd March 2009 08:31 PM
how to determine sensitivity of two drivers wired in paralell? audiophile36 Full Range 13 26th March 2008 11:02 PM
Multi-stage amplification sam9 Solid State 2 5th August 2007 04:49 PM
Sensitivity of multiple drivers? Snickers-is Multi-Way 25 8th February 2005 03:47 AM
High Sensitivity drivers...Where? EngelholmAudio Multi-Way 28 30th April 2002 02:11 AM
Page generated in 0.09946 seconds (67.49% PHP - 32.51% MySQL) with 10 queries
