diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   dipole sub H-Frame, phase or opposite phase ? (http://www.diyaudio.com/forums/multi-way/36329-dipole-sub-h-frame-phase-opposite-phase.html)
mbon 19th June 2004 05:04 PM
I want to try this but do I wire drivers as usual (red on red, black on black so in phase) or in opposition (red on black for one driver)
yes I know this is a stupid question but I've seached and no answer....
http://www.woodartistry.com/linkwitz...May0318-1b.JPG
sreten 19th June 2004 05:13 PM
You wire the drivers in opposite phase so
cone movement is in the same direction.
:) sreten.
mbon 19th June 2004 05:18 PM
:) sreten.
Thank you for so fast and accurate answer !
Svante 19th June 2004 05:24 PM
Come to think of it, what would happen the other way around? It would become a quadropole, right? I'm not saying it would be good, I just wonder what would happen with the directivity and frequency response.
sreten 19th June 2004 07:36 PM
Simply a non-starter, given the module has to be rolled
off to supress the H frame frame resonances, so at lower
effective frequencies the two drivers would simply cancel.
:) sreten.
johninCR 19th June 2004 08:43 PM
It would generate very little sound. I tried it with a W baffle for kicks and it was almost silent.
Svante 19th June 2004 09:36 PM
Yes, it's probably a bad idea, I was just thinking that whatever little that comes out of it could be even more directed than from the dipole.
I think I heard of the opposite once, ie a quadropole microphone. It would be something they used in helicopters to supress ambient noise. Ah, well...
Copyright 1999-2017 diyAudio
