Try Ambiophonics with your speakers - Page 29 - diyAudio
Old 12th April 2010, 04:19 PM   #281
Banned
Originally Posted by durwood View Post
HRTF are an end result, there are many things that comprise HRTF's and crosstalk or if you want to call it vectors instead, are important. You need a vector to determine what HRTF to use.
HRTF is the most correct term.
Panpot is not really "Stereo" although it is label as pan-pot stereo.
Stereo mixes based on interchannel level differences deliver the most stable phantom localization. It doesn't get more "stereo".
That is the problem, the word "stereo" can mean so many things and is very vague.
Not to me. See post #266.
By panning sounds in headphones, it is not real and there are problems. This does not happen in nature. You cannot be deaf to sounds coming from the sides in one ear (unless it is high frequencies), it sounds unnatural. This is the reason for simulating HRTF or adding crossfeed, whatever you want to call it.
Not sure what you are trying to say. Adding a simple crossfeed to headphone playback will not externalize sounds. On the other hand, plugging one ear will not cause sound to be perceived within your head.
Old 12th April 2010, 05:16 PM   #282
durwood is offline durwood  United States
You missed my point. You cannot define a set of HRTF to use without first knowing your vectors. Would you use the same set of HRTF's for speakers at +/-10 vs +/30deg? How about 45deg? 180deg? 0deg?
Totally incorrect, it is actually the opposite. Stereo relies heavily on ITD and does poorly with ILD to acheive a stable soundstage. Move your head a couple inches and the sound changes drastically. Stereo starts falling apart >700hz and by 1.5-3Khz the errors are horrible. Or course it seems to "work" because human speech is within this range so some find it good enough, others reject it.
"2 loudspeakers and the listener form a equilateral triangle. "
If this is all you consider necessary, then good luck to you.
Old 12th April 2010, 05:42 PM   #283
Banned
Quite honestly I don't understand what point you're trying to make. You said "Stereo requires a specific ammount of crosstalk to work." and that's simply not true. Ralph explained why in detail above.
Totally incorrect, it is actually the opposite. Stereo relies heavily on ITD and does poorly with ILD to acheive a stable soundstage. Move your head a couple inches and the sound changes drastically. Lateral localization is very strongly tied to ITD not ILD. "Stereo" = solid, is that really solid?
Well, every mixing engineer will tell you that you're wrong. Phantom sources based on interchannel level differences will result in high localization accuracy which is typical for stereo reproduction. And yes, there is a "stereo seat" and this will always be a problem.
Localization accuracy of lateral phantom sources is typically pretty bad (see Blauert "Spatial Hearing"). You're again mixing up interaural and interchannel cues.
That's the lowest common denominator and typical setup in control rooms. Sorry if you don't like what reality looks like.
Old 12th April 2010, 08:26 PM   #284
Stereo as we know it depending on level differences is a completely artificial effect.
The brain only uses level differences if there are no phase differences for it to work with.
Anybody who ever had a head cold resulting in one ear being partially blocked should have noticed that: While listening to a stereo system is totally messed up we have no problems accurately localizing real sounds.
This has very solid evolutionary reasons.
(Sorry if this has been mentioned before but I did not follow this thread and reading through nearly 300 posts is too time consuming.)
Old 13th April 2010, 03:45 PM   #285
Elias is offline Elias  Finland
Elias's Avatar
Here's a couple of AES papers on cross-talk in stereo
Keele
Part 1:
http://diy-audio.narod.ru/litr/Keele...alk_Part_1.pdf
Part 2:
http://diy-audio.narod.ru/litr/Keele...alk_Part_2.pdf
Old 13th April 2010, 03:56 PM   #286
Banned
Thanks, "Everything you ever wanted to know about crosstalk."
Old 13th April 2010, 04:12 PM   #287
Default Any Polksters here?
Mathew Polk white paper on SDS/SRS technology and their new surround sound.
http://www.polkaudio.com/downloads/w...WhitePaper.pdf
Old 14th April 2010, 02:19 AM   #288
Keele
Part 1:
Part 2:
And here in case those die...
AES Papers -- Official website of D.B.Keele
Old 14th April 2010, 02:24 AM   #289
it's amazing how some of this stuff gets recycled over and over. Give it a few years and someone else will come out something "new"
Position Independent Stereo very similar to polk's SDA.
http://www.extra.research.philips.co...ers/aar01p.pdf
Carver Sonic Holography
Sonic holography - Wikipedia, the free encyclopedia
Unfortunately unless people keep up with trying to promote such ideas it will never take over and eventually people view the gadgets as gimics.
Old 14th April 2010, 03:57 AM   #290
Banned
Does that really make you wonder? There has been so little progress in psychoacoustics within the last 80 years. We're still discussing things that Blumlein already knew (see last few posts about crosstalk in this thread) and still don't know how summing localization works.
Built differences between Guitar Speakers and PA Speakers? agadis PA Systems 7 24th September 2007 08:22 AM
Copyright 1999-2017 diyAudio
