I guess it's reasonable, although a bit more "head in a vise" than having all the speakers at the other end of the room. The delay requirement for it to work is pesky; unsure how to do it with the digital class D amplifiers I'm using. I once had the thought if one could digitally delay all three signals of a I2S connection by the same number of ms; the amplifier output would then be delayed by the same time.
There's a chip that does such a straight time delay of a digital signal, I'm sure.
My Zoudio amps (TAS5825 based) do have some delay that the amp chip offers, however it's in inches of time, versus feet.
Thanks for your reply and sharing! Interesting idea, if you can come up with the bits to get it to work. I didnt know Polk has a current redo of their old SDA technology. I'm currently playing with that on my own; but I'll start my own thread soon.
Why would you need four channels for Ambio?
I've done it various ways, and a plain ol' barrier works pretty darn well. I've done two different setups using a barrier, over the past year or so, and my current set up uses a barrier. I'm just using a sheet of plywood that's covered in Bubos Acoustic Panels.
About seven years ago I (accidentally) stumbled upon a way to do something that's similar to Ambio, but sounded superior IMHO. I can describe how I did it you'd like. I ended up trashing the project because it made everything sound TOO big. The soundstage was distractingly huge.
for 4 speakers . .
here's my ambio setup
The barrier separates a pair of JBL center channel speakers. The JBL speakers are particularly directional on the horizontal axis
I covered the barrier in Bubos sound absorbers (I still need to buy more.)
On my previous setup I had the barrier go nearly all the way down to my desk. You'd think it would be distracting, but surprisingly it's not, especially if you sit exactly equidistant.
It's interesting how the sound stage gets better and better as it gets closer to your face; a gap of even two or three inches is audibly worse than having it come all the way to my face.
Another option that might be worth a look is to apply a little bit of ambio processing (but not a lot.) I find that the electronic processing can sound kinda weird so use it sparingly.
I listen to a lot of podcasts, and for that the ambio setup simply sounds like mono.
Interesting approach!
$80 MiniDSP and you're good to go
If you go with the MiniDSP HD you can also flatten out the phase.
It would definetely be good to flatten the phase
This model? https://www.minidsp.com/products/minidsp-in-a-box/minidsp-2x4
I know it is inconvenient, but a foam barrier worked wonders.
The thing on the software (to me), it can prevent the initial left right ear thing, but to me it cannot defeat the right speaker sound bouncing off the left wall then going into your left ear........
But software driven nearfield (maybe less than 4') it should work really well.
the picture below is an old one, barrier, no software.
When I did a big long barrier, down the middle of the room, the voices were locked and solid in the middle 10' away.
Knock down the barrier, the center image seemed 6db down 3' wide hazy hazy blob.
But, obviously, the giant barrier was an utter pita, and forget watching movies also..............
What intrigues me is I found the graphs roughly backing up what I heard.
With baffle 10' away, the image size (with the barrier), voices were as point source as someone talking.
But good luck with the barrier, no juke-box awesome sound everywhere, no flopping on the couch, and no having tunes while playing vids or poking around the internet on your tablet...................
I've played with this method too. Huge sound field but I could never get it to sound "clean." The divider wall is much purer sounding to my ears than anything that tries to use extra speakers to augment the normal 2 channel arrangement. Lately I've been playing with the simple 3 speaker array matrixed with L-R, L+R, and R-L. The key to this is getting the speakers all fairly close together and in a straight row, and setting yourself an appropriate distance back from the 3 speakers. I find this to provide close to 180 spread on content that does that sort of thing, while still sounding very pure and natural, actually cleaner than 2 channel stereo, which it should. I think this is because for center panned sounds only the center speaker plays. There's not always multiple sound sources that need to be precisely time aligned at your ears so you don't get a bunch of inadvertent comb filtering. I like the way it sounds almost as much as a divider wall. A more advanced version uses a wider spaced set of speakers for the lower frequencies. I tried this at work in a big room we have and it's something new to me to hear excellent imaging maintained as I get further and further back from the speakers. The imaging stays similar but the room tone becomes more obvious. The room reflections are heard affecting the tone but they're not strong enough to upset the imaging. Once I reach the back wall I hear the bass being reinforced and again it seems to be projected on to the entire perceptual sound field, which remains relatively undisturbed by room reflections.OK, so I came up with this accidentally:
A few years back, I was reading about a Bose system that was created for Cadillac. The Bose press release hinted that the system would have noise canceling.
In headphones, the way that noise canceling works is that it records the ambient noise and then simultaneously plays back an inverted version, canceling the noise.
I speculated that someone could achieve something similar without microphones by AUGMENTING what the speakers are playing.
In other words: here's the stereo triangle. What if we ADDED some speakers near the listener, to AUGMENT the sound that's radiated from the loudspeaker itself?
That's an eeenteresting idea!I've played with this method too. Huge sound field but I could never get it to sound "clean." The divider wall is much purer sounding to my ears than anything that tries to use extra speakers to augment the normal 2 channel arrangement. Lately I've been playing with the simple 3 speaker array matrixed with L-R, L+R, and R-L. The key to this is getting the speakers all fairly close together and in a straight row, and setting yourself an appropriate distance back from the 3 speakers. I find this to provide close to 180 spread on content that does that sort of thing, while still sounding very pure and natural, actually cleaner than 2 channel stereo, which it should. I think this is because for center panned sounds only the center speaker plays. There's not always multiple sound sources that need to be precisely time aligned at your ears so you don't get a bunch of inadvertent comb filtering. I like the way it sounds almost as much as a divider wall. A more advanced version uses a wider spaced set of speakers for the lower frequencies. I tried this at work in a big room we have and it's something new to me to hear excellent imaging maintained as I get further and further back from the speakers. The imaging stays similar but the room tone becomes more obvious. The room reflections are heard affecting the tone but they're not strong enough to upset the imaging. Once I reach the back wall I hear the bass being reinforced and again it seems to be projected on to the entire perceptual sound field, which remains relatively undisturbed by room reflections.
All of YouTube is going nuts over this new speaker.
https://us.soundcore.com/products/motion-x600-a3130011
I'm like people, we've been talking about this for decades!
- Try Ambiophonics with your speakers
