I know this may be a dumb idea, and the purists will react with horror, but is it possible to tweak the value of an inductor by partly introducing a small piece of ferrite into the gap, sort of like tuning IF transformers in a superhet....????????
Another dumb question, does an inductor wound on a ferrite toroid behave differently to one wound on ferrite bar? Pete McK |
#2 |
If you are going to go to that trouble, why not just make a multitap inductor?
Yes, toroids are different from rods or bobbins, the ferrite mfg will tell you the design equations. There aren't a lot of toroids made for use in speakers, and buying bobbins and winding your own is probaby more expensive than buying ready-made.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
You can easily tweak an inductor, at least downward in value. Just take off some windings. If you wanted to increase it, you could splice in some varnished wire and add windings.
Everyone has a photographic memory. It's just that most are out of film. |
#4 |
Reminds me of installing a inductor that's wound on a plastic bobbin. If you use ferrous fasteners, the inductance value can go up if the fastener protudes into the centre of the coil. Non ferrous fasteners are a better choice.
Maybe it's a way to tweak with different diameter and length ferrous fasteners screwed down the centre of the coil........ don't know if it's any good for the sound though. |
#5 | |
inductance, I can't see any problems using it to reduce the inductor value. 2) Absolutely, the toroid has far more inductance and it is much easier to saturate the toroids core. A ferrite bar is like an airgapped toroid opened out. |
| Tweaking B&W DM 602 s2 | zverina | Multi-Way | 24 | 4th May 2006 12:12 PM |
| what CD buy for tweaking? | LennyK | Digital Source | 0 | 29th July 2005 08:50 AM |
| Help with car amp tweaking | sq_guy | Car Audio | 15 | 7th May 2005 04:14 AM |
| DIY Amp Tweaking | choatie88 | Solid State | 4 | 15th September 2004 10:16 PM |
| Page generated in 0.10968 seconds (56.75% PHP - 43.25% MySQL) with 10 queries |
