Old 17th June 2004, 05:41 AM   #1
Default Cutting Circles
Can anyone explain to me how to cut perfect circles for a speaker in wood? I've heard that a dremel type rotary tool is not the best for finish work, and that the blades aren't the best. A plunge router was suggested. I have used this style of router before but in a decorative application. So could someone please explain to me how to use a plunge router to cut perfect speaker holes? Or if you have another method I'd love to hear it! Thanks!
Red pill or blue pill....hmmm red for the Redwings and blue for the Blues Brothers...take both and have purple for...for...hey Neo wait up you, which one did you take eh?
Old 17th June 2004, 05:49 AM   #2
blu_line's Avatar
I have used a router to do cut-out circles.
I even managed to make a 5 mm ring of 10cm in diameter of 4 mm thick MDF.
I used a DIY Jig that i bolt onto the router. The jig determines the radius of the circle.
grtz
Simon
Old 17th June 2004, 06:01 AM   #3
Default your jig
Could you please explain to me what your jig looks like/ how it works? Thanks
Old 17th June 2004, 06:11 AM   #4
Mikey p is offline Mikey p  Canada
You can make one cheaply out of 1/4 inch hardboard.
http://www.woodworkingtips.com/etips/etip102000sn.html
This design uses a bolt for a pivot pin, I used a 1 1/4 inch finishing nail with greater accuracy.
Old 17th June 2004, 06:12 AM   #5
Hybrid fourdoor's Avatar
Default Re: Cutting Circles
Are you talking about a RotoZip™? I've seen poeple have good success with those, using the circle attachment.
For larger holes, I just use a Hand Held Scroll Saw, probably not the best. For smaller holes (<5") I use a hole saw, which is a round saw blade that attaches to an electric drill. Usually you can iterchange the hole onto the bit. They usually cut perfect holes, but your limited to more standard sizes, as you won't find something like a 3 3/16, only 3 1/4.
I enjoy my organic shapes.....
Old 17th June 2004, 06:15 AM   #6
nuppe is offline nuppe  Sweden
nuppe's Avatar
I've also made a jig, i posted mine here.
I know, it looks like hell, but it works really great.
I think you can see how it works by the pictures, i'll be happy to answer if you have any questions.
regards
/Andreas
Old 17th June 2004, 08:11 AM   #7
blu_line's Avatar
I used the one Mike put in his message.
Can be used for circles, rings and cut-outs (so speaker are flat with the baffle).
grtz
Simon
Old 17th June 2004, 08:35 AM   #8
Good read, especially for a young newb like me!
http://www.woodworkingtips.com/etips/index.html
Old 17th June 2004, 12:12 PM   #9
Andy G is offline Andy G  Australia
Andy G's Avatar
Default here's a pic for you....
.. hope it helps...
Old 17th June 2004, 12:27 PM   #10
jonz is offline jonz  Canada
Does anybody have an oversize view of a Jasper Circle cutting jig?
DAC cutting out malcontent Digital Source 10 2nd March 2007 09:19 AM
non os for cdp without pcb trace cutting Bernhard Digital Source 16 20th April 2004 03:58 PM
Cutting MDF Vivek Everything Else 11 22nd February 2004 06:30 PM
Cutting circles on mdf gchrist Multi-Way 5 5th September 2002 04:32 PM
Page generated in 0.14138 seconds (62.91% PHP - 37.09% MySQL) with 11 queries
