I did a lot of search on the WWW and have not found it. If you have the driver spec (parameters, frequency response, etc) please send me one or post it here. I bought a pair of speakers with this tweeter and need to redesign the crossover because it does not sound right. I can't do it without the spec. Many thanks, |
#2 |
Esotar T-330 D :
Qms: 0.33 Qes: 0.5 Qts: 0.2 fs: 750 Hz BxL: 4.62 Tm Sd: 7.7 cm^2 Mms: 0.45 g lin x-max: 0.3 mm p-p mech x-max: 3.2 mm p-p Lvc @ 10 kHz: 70 uH Re: 5.2 Ohm If you need the rest also I can mail or fax the sheet. Regards Charles |
#3 | ||
Hi, Was this enough info or do you need more? If so, I have the manufactures info sheet with drawing, dimensions, etc. |
#4 |
Do any of you know whether I can swap a Dynaudio Esotar for an Esotec without having to play around with the existing crossover?
Thanks |
#5 |
#6 |
Thanks David,
| WTB Dynaudio Esotar T330D Tweeter | slhijb | Swap Meet | 3 | 16th February 2012 05:28 PM |
| WTB Esotar T330D | rush1 | Swap Meet | 0 | 20th March 2009 10:48 AM |
| 2-way speaker using T330d esotar & MW170 | barnabam | Multi-Way | 5 | 3rd December 2008 12:04 PM |
| FS: 1pr. Dynaudio Esotar T330D | sacarmic | Swap Meet | 0 | 22nd November 2006 03:39 PM |
| FS: Dynaudio ESOTAR T330D + ESOTAR M560D | zino | Swap Meet | 2 | 17th May 2004 11:55 AM |
| Page generated in 0.10958 seconds (64.85% PHP - 35.15% MySQL) with 10 queries |
