Old 16th June 2004, 08:18 AM   #1
Mark25 is offline Mark25  United Kingdom
Mark25's Avatar
Default Maplins close-out on Audax bass units
They're all cheap now, those that are left anyway!
AP130MO £7.99
AP130G2 £7.99
AP130Z0 £9.99
AP170M0 £9.99
AP210MO £9.99
AP210G6 £9.99
AP210Z0 £14.99
We will pay the price, but we will not count the cost...
Old 16th June 2004, 10:57 AM   #2
Matttcattt's Avatar
They really that cheap? I might order some now...
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 16th June 2004, 11:28 AM   #3
Mark25's Avatar
the prices may be wrong by a few pence here and there, but look at : http://www.maplin.co.uk/Search/Resul...e=Loudspeakers for the full story. It is takes a bit of X referencing to work out which is which in the catalogue, which is why i made the list above. The HP170F0 woofer is NOT reduced BTW.
Old 16th June 2004, 12:51 PM   #4
Did it Himself
richie00boy's Avatar
Cheers
Maplin are to get yet more of my pennies...
Old 17th June 2004, 12:04 PM   #5
bigparsnip's Avatar
cool, now I can actualy build a pair of speakers with those discounted tweeters and not have them dwarf the bass units.
Old 17th June 2004, 12:27 PM   #6
postman is offline postman  Australia
Send a message via ICQ to postman
Wish they had cheap stuff like that in Australia
meh
Old 17th June 2004, 09:00 PM   #7
Kram is offline Kram  United Kingdom
What do you guys think of the AP210M0?
Do you think that 2 of them in one enclosure would work as a semi decent sub for my PC.
How about a 3 way with AP100Z0 and a TM025F1.
Or would I be better off selecting one of the other Audax 8 inchers?
Later
Mark
Old 18th June 2004, 08:46 AM   #8
Did it Himself
Do a search for AP210M0.
In the either the Loud Budget Monitor (UK) or the AP100Z0 thread, I did some comparisons between Audax 8 inch units. Conclusion: AP210M0 isn't up to much.
Old 18th June 2004, 11:31 AM   #9
Mark25's Avatar
maybe you could summarise those findings for us in this thread RB?
In terms of absolute bass extension the M0 looks bad, it's Fo is at least 15 Hz higher than the G6 or Z0.
However, looking at the data sheets the M0 seems to have at least some parameters on its side:
It has about 1/2 the moving mass of the G6 and Z0
it has +/- 1mm extra excursion
the VAS is a lot lower, which i'm guessing allows a smaller cab -> higher WAF.
on the negative side:
Qts is 0.72, pointing towards sealed and the magnet looks to be a lot smaller.
I have 2 G6's and 2 Z0's for comparision, not sure if there's any value in getting 2 of the M0's as well the see what all these parameters mean in listening terms! any thoughts?
I'm not sure about the M0 response curve though, the impeadance peak of resonance seems to be at 150 Hz, not the 47 Hz quoted!
Old 18th June 2004, 11:34 AM   #10
bigparsnip's Avatar
Kram, if you do want to go for one of the two cheeper eight inchers go for the G6 variant over the M0 any day, as these have coated paper cones and a rubber surround in place of the M0's un treated paper cone and foam suround (if you can get down to your local shop and ask them to see the two you will clearly see the difference).
also, if you are going to use any of these with the AP100Z0's, then I would keep an eye on the sensitivities of all of your drivers, as the bigger ones have a fair bit more sensitivity to them compared to the four inchers (you could try using only one eight, with two fours and a single tweeter to help ballence things out a bit, but you would still probably end up needing to balance things out somewhere else).
Maplins close-out on AP100Z0 pinkmouse Multi-Way 514 7th January 2007 10:34 AM
Unknown Audax units boessenkool Multi-Way 13 8th June 2004 07:48 PM
still more Audax drive units Matt D Swap Meet 0 5th November 2003 04:10 AM
Page generated in 0.09721 seconds (79.30% PHP - 20.70% MySQL) with 10 queries
