Old 18th June 2004, 01:30 PM   #11
Did it Himself
richie00boy's Avatar
Mark, you pretty much summed it up there anyway. Bigparsnip also added some good comments, particularly about the surround material.
Fs - too high. Not really much scope for boosting either.
Qts - high, but can be made sensible by Linkwitz Transform or -ve impedance, but useless if you want to go for a normal unaided vented box.
Vas - may be lower than the others, but put an AP210Z0 in the same size box and it will go lower and have lower Qtc. i.e. low Vas does not automatically equate to smaller cabinet - Qts plays a part here as well.
AP210Z0 in 18 litres sealed box
Qtc 0.8074
F3 63.9412
Fc 71.7648
AP210G6 in 18 litres closed box
Qtc 0.6463
F3 86.5931
Fc 78.5249
AP210M0 in 18 litres closed box
Qtc 1.5332
F3 68.8656
Fc 98.8413
mms is not a parameter I look at. Using a sealed box as an example, if 2 drive units when in a box result in the same Qtc and Fc then they will sound the same (with an obvious caveat on SPL) even is one has mms, Qms or Qes 10x that of the other. Impulse response is dictated by Qtc, if these are the same, end of story.
Fs, Qts and Vas are all you need to know about in terms of how it will sound (disregarding SPL).
The Audax data sheet (like all other manufacturers data sheets) measures frequency response in a closed box, hence why resonance has shifted up the band.
Old 18th June 2004, 02:34 PM   #12
Mark25 is offline Mark25  United Kingdom
Mark25's Avatar
Thanks for that comprehensive breakdown Richie. I'm away for 3wks now, should be interesting to see how this thread is developing when i get back.
We will pay the price, but we will not count the cost...
Old 18th June 2004, 05:03 PM   #13
Matttcattt's Avatar
If I were you, I would be worried that the drivers were discontinued and out of stock by the time that I got back.
I buy first, plan later. Then you can use the left over drivers as an excuse for the next project...
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 18th June 2004, 07:46 PM   #14
Mark25's Avatar
as mentioned in a previous post, i already have 2xG6 and 2xZ0 delivered, i just want to try and make sure i'm not missing anything special about the M0. I'm visiting the "Island" anyway, so will be ideally placed to "top up".
Mark
Old 18th June 2004, 10:25 PM   #15
Matttcattt's Avatar
Mark
Oh, must have missed that.
Old 28th June 2004, 01:33 AM   #16
nubbins is offline nubbins  United Kingdom
Price reduction :
AP130MO £4.98
AP130G2 £4.98
AP130Z0 £4.98
Maplins close-out on AP100Z0 pinkmouse Multi-Way 514 7th January 2007 10:34 AM
Unknown Audax units boessenkool Multi-Way 13 8th June 2004 07:48 PM
still more Audax drive units Matt D Swap Meet 0 5th November 2003 04:10 AM
Page generated in 0.08523 seconds (79.15% PHP - 20.85% MySQL) with 10 queries
