2.5 way impedance
2.5 way impedance
Old 15th June 2004, 05:18 PM   #1
Vivek is offline Vivek  India
Default 2.5 way impedance
This question is going to be incredibly stupid. Please bear with me. While building a 2.5 way system using two 8 ohm midbass units, the nominal impedance of the system till the tweeter crossover frequency will still remain 8 ohm, right?
One more thing. Are there any good websites to learn about 2.5 way speaker design?
Thanks,
Vivek
Thank God for DIY audio.
Old 15th June 2004, 05:31 PM   #2
diyAudio Member RIP
No. Its 4 ohm bass and 8 ohm midrange, sreten.
Old 15th June 2004, 05:34 PM   #3
Thanks for that reply but how does the impedance change?
Vivek
Old 15th June 2004, 05:47 PM   #4
Svante is offline Svante  Sweden
Svante's Avatar
Just like Sreten said, it is four ohms for low frequencies and 8 ohms for mid frequencies. At low frequencies, both drivers are effectively connected in parallel, at mid frequencies a series coil effectively disconnects one of the drivers.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 15th June 2004, 05:48 PM   #5
diyAudio Member RIP
It changes at the 0.5 way point ~ 350Hz, sreten.
Old 15th June 2004, 05:51 PM   #6
Got it. Thanks a million.
Vivek
2.5 way impedanceHide this!Advertise here!
What impedance? jaya000 Multi-Way 11 21st November 2008 07:04 AM
Impedance rate VS impedance stability TomatoBangBang Tubes / Valves 6 4th September 2008 10:46 PM
Hi Vi SD1.1 impedance guitarded Multi-Way 0 3rd February 2008 08:35 AM
Impedance and SPL.. TroelsM Multi-Way 5 26th September 2005 12:52 PM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
Copyright ©1999-2017 diyAudio
