Old 15th June 2004, 02:33 PM   #1
Rocky is offline Rocky  Norway
Rocky's Avatar
Question SPL loss with passive XOs
Is there any mathematical way to predict the SPL loss a passive XO causes on a drivers rated SPL (in dB/W/m)?
As an example, take an 8 ohms driver with a 97dB/W/m sensitivity and add a 2nd order low pass filter.. What would be the resultant sensitivity, and how can it be calculated? Is there any precautions one can take in selection of crossover components to minimize this loss (coil resistance etc.)?
Old 15th June 2004, 02:48 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
The loss for a 2nd LP order filter in the passband would approximately be a simple voltage divider between the filter coil resistance and the driver impedance. For most applications this loss would be well below a dB. Example: 0.5 ohm coil resistance 8 ohm speaker; 8/(8+0.5)=0.94 or 0.5 dB.
As the impedance of the driver varies, so will this attenuation, and at the fs impedance peak, the attenuation will be even smaller. In effect this will lead to a relatively higher sensitivity at fs. Another way of understanding the same thing is that the driver, with the series resistance included, has a higher Qes (and Qts).
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 15th June 2004, 02:53 PM   #3
Rocky's Avatar
That is indeed what I call a quick and precise response, Svante.
Thank you for kindly sharing your infinite wisdom
Passive Pre-Amp causes huge power loss? Dominick22 Tubes / Valves 9 28th September 2006 11:34 AM
Loss Of Sound Docc25 Car Audio 0 24th February 2005 07:39 AM
At a loss... cunningham Class D 21 23rd September 2004 07:29 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 10:16 PM
Page generated in 0.07910 seconds (70.35% PHP - 29.65% MySQL) with 10 queries
