Old 15th June 2004, 12:25 AM   #1
Default Woofer Towers, front-ported or rear-ported?
Hello! I'm almost finished my bass towers, each is about 30" high by 11.5" high, and 17" deep. All in all, minus the braces, the volume is 70 liters.
Each of these towers will house a Focal 11" Polykevlar woofer. These two towers will be mating to an Open baffle MT portion in the likeness of the Linkwitz Orion. I will be crossing at 120hz.
This is for a music system, looking to remove any boomy sound if possible. So should I front port these bass towers, and thereby have the advantage of placing them closer to the front wall, or should I rear-port them. I am looking for the best and most articulate bass using these drivers that I can get. Keep in mind that I'll be crossing at 120hz with a LR4 XO. I'll be ready to cut the driver and port holes in a week, so all input is welcome.
Look forward to your opinions!
Old 15th June 2004, 01:33 AM   #2
Being the fanatic as suggested in the catch phrase of the forum...build it SEALED.....everything will be better.
Old 15th June 2004, 02:40 AM   #3
qvinson, I've definately considered that. But some of the reasons I chose to do a ported was because I have heard these woofers in ported 3ways, and it was amazing. No boom at all, but the room was large, thats why I'm worried that the front/rear thing might make a difference in my smallish room.
I guess I could still do it sealed, but the F3 would rise from 33hz (anechoic) to about 55hz. I know that inroom it will be better, but still it doesn't look great. Also, I've already built 70 litre enclosures, and the volume required for a sealed Focal 11K is about 37 litres. So I'm almost double the size.
But, keep the suggestions coming!
Old 15th June 2004, 02:46 AM   #4
Also, another reason I chose ported was because two different DIY'ers that have used this woofer ported, preferred them to sealed Scanspeak 8565 10" woofers. This leads me to beleive that if you match speakers with the right enclosures, they can defy common audiophile "rules". I will also be using parametric EQ on these woofers to tame the in-room response.
Old 15th June 2004, 03:09 AM   #5
frugal-phile(tm)
planet10's Avatar
And better than sealed, IMHO, is an aperiodic, or TL box... to turn your ported box into aperiodic box (TL is no doubt out of the question at this point), stuff the port with something with high acoustic resistance -- to reverse it pull it out. I don't often build BRs, (i do do ML-QW) but i like the port out the bottom -- if that doesn't work then out the back.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th June 2004, 02:01 PM   #6
Golden...I understand the trade offs one has to make....it is just a measurable reality that sealed boxes offer advantages on so many fronts that they become hard to ignore, while having very few disadvantages.....and you are quite correct, some of the most admired designs that have been commerccially available are ported for their own reasons.....yet......bottom line: best of luck with your project. Let us know your results.
Old 15th June 2004, 06:44 PM   #7
Banned
Default Put the port in the back
With the port in the back you have the option of gaining boundary reinforcement of the port output if you place the speaker close enough to the wall, or not by pulling it away. Booming is not a problem since that phenomenom takes place in the 80 to 160 Hz octave while the port only passes frequencies in the octave or two below that, depending on the box frequency.
low frequency room response - front vs. rear ported JLC7 Multi-Way 0 3rd May 2009 02:04 AM
Front Ported Zaph zbm4 Project Thread BionicSniper Multi-Way 6 26th August 2008 03:58 PM
2 way, front ported, stand mount, HELP nordhaven Multi-Way 4 8th March 2008 01:33 PM
Discussion about ported bookshelves/towers with sealed subwoofers simon5 Multi-Way 1 23rd June 2005 03:34 PM
what size sealed or ported box can this woofer use ? zuki Multi-Way 2 23rd November 2004 02:20 AM
Page generated in 0.14441 seconds (54.60% PHP - 45.40% MySQL) with 10 queries
