Old 16th May 2002, 09:32 PM   #1
Stew320 is offline Stew320  Shetland Islands
Send a message via MSN to Stew320 Send a message via Yahoo to Stew320
Default 24" sub for DIY ?
Has any of you builders tried the Precision Devices Prestige Series - PD 2450 driver for a DIY Sub??
Hears the link http://www.papl.co.uk/asps/ShowDetails.asp?id=17
Im very interested in using it in my next project ;-)
Any comments on this driver?
Cheers
Stewart.
Old 16th May 2002, 10:33 PM   #2
Apogee is offline Apogee  United States
Apogee's Avatar
Hope you have a HUGE room if you decide to build it...
Your system will be faster and go lower if you consider using the Bag End ELF technology instead... I've just replied to another sub post here:
http://www.diyaudio.com/forums/showt...0925#post30925
Specifically, check out the links on the ELF technology...
If you build it, good luck. Hope your house is built well....
And no, I don't work for Bag End...
Steve
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 5 13th October 2012 05:18 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
