Old 28th August 2002, 09:53 AM   #21
Andy G is offline Andy G  Australia
Andy G's Avatar
Default these drivers......
... ok, I have had a look at the curves etc. and make the following comments re suitability
The TC18 has a broad rise in the 2k - 5k range, the TC26 is NICE !!
That broad rise would be accentuated with a low zeta x-o, and the sound would probably be very forward.
What I would do with this pairing is to cross higher, say 3k, use an slightly over-damped zobel on the woofer, and use a zeta of about 1.3 to counteract the rise in response of the TC18. Since you are using it with a sub, i don't imagine any bass boost needs to be added.
If you like I will put together a possible x-o diagram that should do a reasonable job, but seeing I haven't actually used either driver, would need some tweaking.
Email me if interested.
Old 28th August 2002, 11:50 AM   #22
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Andy that would be great. I am new to series XO.
I prefer a laid back sound. how does one use an slightly over-damped zobel on the woofer? will a higher zeta (1.3) mean a lower slope (less than 6db/oct)?
Also at 3k the tweeter would be better protected so I woudl prefer 3k. I was just afraid ofteh rise in the woofer response and hence chose 2k.
Thanks again in advance.
regards
navin
...still looking for the holy grail.
Old 28th August 2002, 11:22 PM   #23
Andy G's Avatar
Default email me !!
I will need to send a diagram, so I need your email address.
If you email me I can reply with necessary info and diagram.
email address removed -- please see post below. dave (moderator hat)
Old 29th August 2002, 05:13 AM   #24
navin's Avatar
will do.
thanks in advance.
navin
Old 4th September 2002, 06:39 AM   #25
navin's Avatar
Andy,
Do I need difraction compensation?
Old 4th September 2002, 07:15 AM   #26
frugal-phile(tm)
planet10's Avatar
Default Re: email me !!
Originally posted by Andy Graddon
If you email me
Andy, All. We are starting to discourage the use of email addresses in the posts so as to discourage the SPAMbots that go out and find addresses to send SPAM to.
Please use the email button at the bottom of the post.
dave (moderator hat on)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th September 2002, 07:25 AM   #27
Andy G's Avatar
Cool okey dokey !!!
I will try to remember !!
OS-CON in series for Xover? thespeakerguy Multi-Way 0 7th September 2008 06:13 AM
2nd order LR series xover formulae PeteMcK Multi-Way 30 9th June 2007 07:27 AM
series Xover Doc.Doom Multi-Way 1 19th September 2006 06:38 AM
!st order series xover between 5"FR and woofer?? johnmark Full Range 1 2nd May 2005 12:40 AM
Parallel and series components in xover andy2 Multi-Way 7 22nd November 2004 04:32 PM
Page generated in 0.16358 seconds (43.76% PHP - 56.24% MySQL) with 10 queries
