hello
i am very gutted just bought a brand new set of loudspeakers and found out that they wont connect to the amp. because the conections on the speaker and jack to jack and the connections on my amplifier are just standard speaker connections. WHAT DO I DO? any info would be great cheers HBS_CODE47 |
#2 |
Banned
Buy a set of plugs for each end and some cable and build your own.
#3 |
I don't know what you mean by "normal". However: buy some "normal" plugs Red & black) some mono jack plugs. and some heavy flex. It does not really matter which way round you wire then as long as both are the same. This is to keep the speakers in phase with each other. Usually, I would wire red or "+" (or whatever you have) to the tip of the jack.
#4 |
Just to check... the speakers are not self-powered, I hope. If they have built in amplifiers, you don't want to plug them in to your amp very bad.
| How to connect a set of loudspeakers to computer.. | Jshen | Multi-Way | 16 | 25th March 2007 02:03 AM |
| tape wont record | sdoom | Everything Else | 13 | 21st July 2006 05:07 AM |
| wont turn on | IMPALAMAN1 | Car Audio | 17 | 1st February 2006 03:53 PM |
| cambridge wont stabilize | homertooties | Solid State | 6 | 7th December 2005 10:12 PM |
| Page generated in 0.09237 seconds (57.12% PHP - 42.88% MySQL) with 10 queries |
